800+ hp sierra
Old Dec 30, 2015 | 09:57 PM
Slow53's Avatar
Sorry just lurking around and wanted to say that's a beautiful motor. Looking good very tasteful
Old Dec 31, 2015 | 03:31 AM
sguiffre13's Avatar
Originally Posted by George C....
Gonna need much larger gate then a 46 to properly control that turbo
I have a precision 66mm for a s475 t6 1.32 96 combo
Did a manifold for someone who had a billet s480 and uses a jegs 50mm and has creep...gate placement is similar
The manifold I have says it has a 46mm flange for the wastegate, would I be able to run a bigger gate then a 46 then? Is the size of the flange on the manifold and the size of the gate different?
But time for an update. Its 4 AM here and I just came inside (Im used to being up at night as I work nights) but I went out and officially picked up the truck and got it home. It also is very torn down already.
A little background info on it: its a 2000 GMC Sierra, Pewter in color, SCSB 2wd and it is also a step side. The truck is 100% rust free as it came from Louisiana ( its a big deal here in Michigan), and has a few scratches and minor dents and the clear coat is peeling slightly. It was a v6 truck and the motor blew, the motor and trans were already pulled and in the bed.
When I got it in the garage
Got the bed pulled off
Core support/ front bumper/ engine harness off.
As it sits for the night
I will get further with it tomorrow and will most likely have another update. Im getting ready to do another parts order and I think Im going to get some undercoating for the frame and plumb the fuel system/ get the pumps and set that up.
Just wanted to say thanks to everyone again for the help so far on this.
Old Dec 31, 2015 | 03:33 AM
sguiffre13's Avatar
Thanks! I figured if I was building it before I had the truck I may as well make it look as good as possible
Old Dec 31, 2015 | 08:46 AM
George C....'s Avatar
Formerly ScreamingL
You may have to add another gate in the crossover
Old Dec 31, 2015 | 12:40 PM
sguiffre13's Avatar
Oh, that's fine as I am going to just make my own crossover instead of buying one. Thanks for clearing that up though.
Old Jan 8, 2016 | 07:35 PM
sguiffre13's Avatar
So over the last few days I've continued stripping the truck down and getting the frame ready for paint. I ordered a gallon of POR 15 that should be here sometime next week. I am starting to get all my stuff together to start the fuel system and I am running into a problem that has me stumped. So I see everyone running dual pumps in a factory returnless bucket as the returnless one is bigger but I dropped the factory tank out of the truck and was looking at the bucket and I noticed that there is no room for a wider bucket in this tank due to the hole in the top of the tank being only slightly larger than the bucket. My question is, do the v6 trucks have a different tank and sending unit than the v8 trucks? or are the returnless tanks usless as well?
more updates coming soon, I just need to make up my mind on what project I am going to tackle next.
Old Jan 8, 2016 | 07:43 PM
Formerly ScreamingL
I ran dual 255s in a factory bucket...setup is good for 1000rwhp on gas
Also took me over a gallon to paint my frame on my truck
Old Jan 8, 2016 | 08:08 PM
sguiffre13's Avatar
looks like ill be ordering more paint then, I was reading that many people used a little over 3 qts for the frame but I guess ill find out.
Is your bucket returnless? I have my factory bucket and factory pump in front of me and if I had two of them I feel like they wouldnt fit even with heavy modification
Old Jan 8, 2016 | 08:29 PM
Formerly ScreamingL
My old fuel system was 2002 bucket...ran that up until i went belt drive
I used rustoleum and used gallon and quart but also did my floor
Old Jan 8, 2016 | 09:40 PM
sguiffre13's Avatar
do you by chance have any pics of your pumps and how they are set up? I am trying to figure out what all I will have to cut out of this bucket to make it work
