6.0 Turbo build
Old Nov 28, 2013 | 02:03 PM
Atomic's Avatar
I have a gauge for that
stock head bolts tend to break off in the block when you re use them.
Old Nov 28, 2013 | 04:13 PM
GRRR65GTO's Avatar
Oh i thought he was talking about head studs or something aftermarket. Yeah i got all new gm bolts
Old Nov 29, 2013 | 11:17 PM
GRRR65GTO's Avatar
I just mocked everything up today and I ended up shoving the radiator and condenser back like 2 inches and now I have plenty of room for the intercooler and trans cooler. Granted I did cut out the hood latch a frame and I still have to redo it
2013-11-29182647_zpsa05596ab.jpg?t=1385787470
2013-11-29182704_zpsd2f6438a.jpg?t=1385787486
New brackets for condenser to sit on
2013-11-29230011_zps5c27ae89.jpg?t=1385787506
Old Dec 2, 2013 | 09:57 AM
Bama2door's Avatar
Yea not a fun time...
Old Dec 2, 2013 | 07:02 PM
GRRR65GTO's Avatar
So the trucks running now. I started it at about 3 am this morning, slept for 3 hours and then drove it to school. The oil drain didnt exactly comeout how I had hoped...
There was less room than I thought between the A/C belt and the water pump cause thats where I was gonna run it, so instead I notched out some of the compressor bracket and got this. I have a bad feeling that its not a good enough gravity drain so I was hoping someone could tell me if it'll work or not.
2013-12-01214908_zps400bf4ea.jpg?t=1385952769
I took the oil cooler lines off and tapped the block, drilling from the back so there was no guessing whats on the other side of what im drilling into. I capped it for now since I dont have the turbo on yet
2013-12-01160428_zps84c5d8ce.jpg?t=1385952780
2013-12-01164357_zps7da2ce60.jpg?t=1385952796
Oh and I was smart and forgot to order a longer crank pulley bolt and of course no stores had one around me so I made one, well kinda, my dads a better welder so he welded it
2013-12-01214954_zps44b93bae.jpg?t=1385952735
2013-12-01215006_zps0808e52c.jpg?t=1385952713
Old Dec 2, 2013 | 07:23 PM
GRRR65GTO's Avatar
Now that I found out about the bad reveiws of the smartfire injectors would these be a another injector that would work if they do turn out to be bad?
Siemens Deka V 80lb HR Fuel Injectors Fit EV1 Bosch Short Stubby Pico D5 840cc 8 | eBay
Old Dec 3, 2013 | 09:21 PM
GRRR65GTO's Avatar
Im not asking for much just a few peoples opinions and input...
Old Dec 3, 2013 | 09:50 PM
Atomic's Avatar
Deka 80s are fine injectors, very common. I think I saw a set in the classifieds for $300 or so...
Old Dec 3, 2013 | 09:56 PM
GRRR65GTO's Avatar
Ok i think im gonna return the smartfire ones and just get deka ones. Which kind is the right kind or will both work? The short vs tall
http://pages.ebay.com/motors/link/?n...d=390684290068
Old Dec 3, 2013 | 11:48 PM
kelsey_canard's Avatar
yea, good decision on ditching those smartfire injectors. I am running the siemens deka 80s. I'd go with the tall injectors, as it is cheaper to space the fuel rail up than it is to space the injectors up.
