6.0 Turbo build
#151
You can try a different vac/boost source. I use my old brake booster line for vac/boost source for my wg,bov, and gauges since I did a hydro boost conversion.
#152
im kind of fighting same thing. 11.6WG spring in my tial but its only making 9-10lbs of boost. however im pulling the source of my boost off the turbo housing before the IC so that is prob why im losing a little. Im going to try pulling the boost reference off my vac block that is showing actual manifold pressure
#153
One would think the boost on either side of the throttle blade would be the same because my reference line is before the throttle blade
#155
Its hits 7 no problem and as it revs up to shift it starts falling down to 4 or 5. I know an electronic controller can compensate for that buts its not a race truck
#156
you have another problem if its not holding spring pressure. a BC would just be a bandaid.
if its a 7lb spring it should have no issues holding 7 from start to finish. Do you have a Vacuum block or anything. I would double and triple check the line to the WG and maybe run a new line from either the intake manifold or a vac block
#160
I think this is predominantly an issue with the small turbine on that turbo. I'm seeing a similar issue with my baby 74mm turbine, which isn't helped by the fact that I've got about a mile of 4" piping behind it. I'm sure a cutout would help tremendously. This issue seems to be boost controller independent in my case as eventhough I increase the overall boost, the boost curve stays the same.
