6.0 Stick Shift Tahoe (NV4500)
Old Apr 1, 2020 | 08:44 PM
  #91
_zebra's Avatar
makes children cry
guy i work with put a 14bolt rear in his '08 ECSB 4x4 after he did a procharged LS3 swap. said it wasn't too bad.
Old Apr 1, 2020 | 09:51 PM
  #92
arthursc2's Avatar
It's easy. Takes more time to swap a trans than the rear, IMO
Old Apr 1, 2020 | 10:18 PM
  #93
dantheman1540's Avatar
Contemplating the Spohn link kit minus the panhard bar.
Old Apr 3, 2020 | 09:33 AM
  #94
It came sooner than expected and has the denali links and sway bars which is kinda nice.
Old Apr 3, 2020 | 02:34 PM
  #95
2002_Z28_Six_Speed's Avatar
That is a cool piece. So is that a GMT900 SUV rear? Is it 1500 or 2500? I don't think 2500's came with a 4 link but I thought I would ask.
Old Apr 3, 2020 | 02:41 PM
  #96
The VIN this came out of is from a 2011 Yukon Denali 1500 with a 6.2, 6l80, and 2wd. Says it had 152k miles 3.42 gears a posi and lived its entire life in south Florida which seems true as there's nearly no rust.
Old Apr 3, 2020 | 06:02 PM
  #97
arthursc2's Avatar
2500s are leaf out back
the "14b" is just a 9.5" SF light duty axle. They are pretty strong, nearly 7k GAWR, and they are of course from the AAM 9.xx family, so bearings, lockers, gears and covers interchange with a whole family of axles; both front and rear. So parts are cheap 👌🏻
Old Apr 3, 2020 | 10:11 PM
  #98
It surprised me how limited the gear ratios are. 3.42 is the highest I could get would have probably done 3.08s
Old Apr 4, 2020 | 01:52 AM
  #99
_zebra's Avatar
makes children cry
yeah, i ran the math on 3.08s a while back... what gets you close to the original nv3500 starting ratios would make for a dog on the highway because 4th & 5th are the same.
granted, depending on whether you're talking blown/cammed 6.0 in a 5000lb truck or cam-only 6.0 in a 6000lb truck, it could make the difference in acceptable loss.
Old Apr 4, 2020 | 07:44 AM
  #100
I think 3.08s would be great in this thing because it has pretty high compression and the small cam. 5th would be for cruising only and if I needed to pass someone quickly I could always drop a gear. After driving the silverado last night and seeing how useless 2nd gear is now with much more power it makes me want to go to 3.73s if/when its 10bolt dies. But then again I like how I can start from a stop in 3rd gear in both trucks. Makes it like driving a 3 speed and you hardly have to shift if you don't want to.
