427 Lsx twin turbo/4l80 awd SS build
well i guess its my turn my final part for the motor showed up so ill start my thread.
rick @ synergy will be partaking in the turbos and 80e. this setup will be similar to marks(2004 denali) build.
so far motor specs are as follows.
lsx gmpp block (head bolts will be 1/2 inch with the 6 bolt heads)
trickflow 235 cc 6 bolt heads with inconel exhaust valves and .650 lift springs
callies 4.00 x 6.125 rod 2.100 journal dragonslayer crank
lunati pro billet 6.125 i beam connecting rods w 225,000 psi bolts
diamond 4.125 custom coated pistons
morel ls1 hydraulic lifters
yella terra ultralite rockers
asp damper
cam specs are on the way
turbo specs are somewhat set but not set in stone
pictures of some parts below
still undeceided on an intake manifold. but here are some pics of parts
asp damper
our trucks should be very similar erik. except the drivetrain. which i think will be a challenge as well for me.
the transmission had always been the limitation on the awd trucks. i think with a built 80e the other weak spots will show. im just hoping the front diff can hold because there isnt much i can do to add stregnth there.
my goals are a bit high but hopefully attainable, 1000awhp and 10's with ease. low 10's would be awesome and maybe for ***** and giggles ill put it on a diet and see what happens.
SUBSCRIBE
