2014 Silverado 4/7 drop, cal-tracs, coil overs. More to come
#21
No problem that's the reason we are all on this forum. I wish my suspension was finished but i turned my attention to the drivetrain. But i will be back on it soon. Going to build a tri-link and use the Vikings first then get some Ridetech later.
#29
Thanks fellas. They are Viking shocks and coil overs. They ride a lot better than the factory shocks with drop cups and the rear shocks from mcgaugys. C210t is the part number of the coilover. The spring is part number 12dp600. They are like 250 each for coil overs with spring. I'm still tuning on them to get them completely right for my setup. I also have pro-comp coilover mounts. Unless your truck is dropped 4" up front these coilover will be different than you would need. My front ride height is 14 1/2"
you sure about this? I ordered mine today and Jake at Viking told me that the CxxxT is for the standard 3" T-Bar which wont work for our trucks. The C210 shock would work with the 7935-103 5" T-Bark kit needed to make it fit our lowers.
