2012 RCSB 416ci TVS2300
Old Apr 2, 2013 | 04:43 PM
  #201
silverado6.2's Avatar
Originally Posted by Atomic
The first 30 minutes /20 miles of an engines life are the most important in terms of making it last. You need to vary the rpm and cylinder pressures a lot, hence why the best break in procedure is spirited city driving!
Isn't the 30 minutes while you vary engine rpm mostly for flat tappet cam break in?
Old Apr 2, 2013 | 04:51 PM
  #202
Denali08's Avatar
To properly seat the rings, you need to apply and vary the load on the engine as Atomic mentioned.
Initial start, you need to rev it above 2000 rpm to avoid low speed/high friction which could wear the cam lobes. This is as recommended by cam manufacturers.
Old Apr 2, 2013 | 09:16 PM
  #203
oakley6575's Avatar
I like to run it up the street a couple times in first/second gear letting it slow down by engine braking. Run the truck up to 4000rpms at a moderate pace in first gear and let off the gas. That should load the engine enough for the rings to settle. Spirited driving is a good way to say it
Old Apr 4, 2013 | 08:26 AM
  #204
supercharged680's Avatar
Ran across a little issue before installing the blower, i noticed the valley cover was missing.. so i looked around in the shop... nothing.. i drove an hour to my storage room at my dad's farm.. nothing.. so i call the guy i sold my old 6.2 block to and i asked him do u have a valley cover on the block? he said no.. so i lost all hope and had to spend more money and another 3-4 days till it gets here but then! i asked that guy to take a pic.. cause i wanted to double check after he sent me a pic i started laughing cause he took a pic of the bottom side..
i told him to flip it over and take a pic again.. *drum rolls* tadaaaaaa found it! truck should be running on saturday, cause they close on friday.. im having a good day so far *knocks on wood*
Old Apr 4, 2013 | 08:39 AM
  #205
ak2007r6's Avatar
Lol. Looking forward to hearing it run
Old Apr 4, 2013 | 09:16 AM
  #206
Denali08's Avatar
Make sure he doesn't intall it upside down with blower in place of the oil pan..looooooooooool.
GL.
Old Apr 4, 2013 | 03:46 PM
  #207
AlljackedupZ71's Avatar
What an awesome build dude.
Can't wait to see the #'s on this thing.
Old Apr 6, 2013 | 08:22 AM
  #208
Thanks dude!
First start up in 2-3 hours.. The most nerve-wrecking moment
Old Apr 6, 2013 | 03:47 PM
  #209
its ALIVE! we couldn't go street tuning today because it was raining that sucked.. oh well atleast i drove it back home parked it and called it a day. So hopefully tomorrow it should be tuned and ready to go if the weather is good!
Thanks to Frank and Zippy @ Revolution Race Works and Mike @ New Era Performance
Old Apr 6, 2013 | 03:59 PM
  #210
ak2007r6's Avatar
Sounds good.
But holy cow your truck is filthy LOL
