2003 Silverado turbo build..
Old Mar 28, 2017 | 08:40 PM
  #31
Csnell3732's Avatar
Made some progress today! Fitted single walbro 450 in fuel bucket and installed it and tested my fuel system for leaks. Wrapped my turbo log...and started on my 15inch conversion in the rear, just waiting about my new tires to show up and it should be done! Also prepped the trans to be installed!
[IMG]https://cimg1.ibsrv.net/gimg/www.performancetrucks.net-vbulletin/2000x1504/80-
image_6cce8052f62ebd4d3aba88127a8679b374849b6b.jpe g[/IMG]
Old Mar 29, 2017 | 11:25 AM
  #32
zblee's Avatar
the 15" conversion requires removal of e-brake right? what did you do with it? did you remove the line all the way up to the pedal and remove the pedal assembly?
_Zblee
Old Mar 29, 2017 | 08:13 PM
  #33
Csnell3732's Avatar
_Zblee
Yeah it doesn't allow you to utilize the ebrake anymore so I removed it all the way up to pedal and left the pedal!
Old Mar 29, 2017 | 08:20 PM
  #34
Csnell3732's Avatar
Default Little progress made today!!
Few pics of the 15 inch conversion
Trans installed!!
Oil feed for the turbo!
Drilled out the feed
Taped and ready to go!
Oil feed!!
Tyler Scruggs crossmember
Fitting the exhaust down pipe!
Oil drain line!
New tires!! Mickey thompsons 295/55
Wrapped the hot side!
Old Mar 30, 2017 | 08:27 AM
  #35
2KRedSilverado's Avatar
Sweet! Good progress on this man, keep it up!
Old Mar 31, 2017 | 11:16 AM
  #36
Csnell3732's Avatar
Thanks man I'm really trying to get this thing going within the next few weeks!
Old Mar 31, 2017 | 11:19 AM
  #37
Csnell3732's Avatar
4 inch core made it in!
Decided to get the cold side powder coated it turned out awesome!
Old Apr 4, 2017 | 10:30 PM
  #38
Csnell3732's Avatar
Not really much to show... been working on a lot of small things mounting brackets and fine fitting the kit and slowly piecing it together for the last time. Got tries mounted and started would on my transmission cooler location and mounting/making lines for it. Getting pretty close to firing the truck up...
Old Apr 10, 2017 | 09:32 PM
  #39
Csnell3732's Avatar
Well finall installation of the turbo kit!! Mounted alky progressive controller. And manual boost gauge,trans brake activation Led!
Trans brake activation LED
Boost gauge... and alky control
New driveshaft!
Solid joints!
Old Apr 12, 2017 | 11:08 PM
  #40
Csnell3732's Avatar
Made a lot of progress over the last week or two... turbo kit is installed and finished! Just waiting on meth tank from trick performance and it'll be off to get tuned! I'll up load some more pics few pictures of other things I did tomorrow! Overall very happy with how clean it turned out! Fired it up earlier today for few seconds to make sure everything checks out before tuner comes over!
