2003 Silverado turbo build..
Old 03-13-2017, 05:23 PM
  #21
Csnell3732's Avatar
Super happy with Pcv wild can! Nice and clean install hard to beat the quality is nice and kit came with everything I need to do this install! Mighty Mouse for the win! Also mounted the two step!
Alternator mounting bracket
-10an oil cap fitting
Did little trimming to clear the hose
Little 2step action! Found my mounting location
Old 03-14-2017, 10:55 PM
  #22
Csnell3732's Avatar
Granted I'm not a fan of the tan but my trans guy uses it for his stuff lol why this color I will never know I've asked several times.... But brief run down of what she's got inside!!
D1 transbrake
2nd gear snap ring support
Internally dual fed
Custom direct frictions
Accumulator block off plate
Sonnax line rise kit
Billet forward clutch hub
Billet input shaft
This thing will take a beating!
Trans is ready for action!
Old 03-15-2017, 06:36 AM
  #23
03sierraslt's Avatar
Nice build. I have a MM catch cam also, they are nice.
Old 03-15-2017, 05:08 PM
  #24
mikealicious2k5's Avatar
sweet setup. curious to see what numbers it puts down when all said and done.
curious to what stall speed you chose?
Old 03-16-2017, 09:40 PM
  #25
Csnell3732's Avatar
Default 15inch rear conversion parts!!
Well I sold my 17s in the rear so I could go to a 15s in the rear! Got the kit in today along with wheels!
Old 03-27-2017, 10:42 PM
  #26
Csnell3732's Avatar
Default Time to get back at the build!! Vacation is over!
Well took little time off and went on vacation with the wife... In the mean time my kit came in so here's few pics of the fab work and test fitment pictures. All in all kit isn't bad fitment seems good on with cold side and the turbo mainfold seems nice and durable. My only complaint was the debris left inside the piping. Had to debur the cold side and removed some slag on the Hotside left in it and throughly clean all the piping due to metal shavings. Was sent the wrong innercooler waiting to see if they make it right and send the 4 inch out. The headlight buckets did require a lot of trimming I ended up having about hour in each headlight bucket to get everything to fit and mount properly.
Old 03-28-2017, 02:58 PM
  #27
Tydriver's Avatar
I must have missed it, but what turbo kit did you go with ?
Old 03-28-2017, 03:41 PM
  #28
rpm-inc's Avatar
Looks great. Doing something very similar but not as nice for my beat up 05 2500hd regular cab. Single walbro 450, 243 heads, 7875, china studs. Stock cam and converter for now.
Old 03-28-2017, 08:34 PM
  #29
Csnell3732's Avatar
Went with spike performance kit.
Old 03-28-2017, 08:36 PM
  #30
Csnell3732's Avatar
Nice!! I actually have a 07 classic 2500 hd I thought about doing a turbo on it... I have a extra 78/75 billet wheel turbo brand new in a box I won on a raffle that I'm not sure what I'll do with it yet!
