2003 Silverado RCSB Z71 6.0/ZL1 Blower & 4L80e/NP241 Swap
Finally got around to cutting a hole in my transmission tunnel to install the factory style floor shifter. Also removed the factory AutoTrac buttons and installed a toggle to activate the front actuator manually. This way I can also have '2Lo' for backing up my travel trailer in tight spaces.
Ford_Assassin (09-11-2017)
It looks innocent until you hear it. Speed Engineering mufflers are not nearly enough to quiet the truck down. I get asked all the time if the truck is straight piped. I have an appointment tomorrow with a muffler shop. Either going to add two Magnaflow knockoffs, or one large 22x11x5" dual in/out suitcase muffler.
Yesterday was the first time I was able to do a AWD launch, even then it was on a crappy stretch of road in the sticks. I will say this, ****** could probably hook in a car wash. Did two launches, first one I footbraked until 2k and let it go, 2nd from a dig, no footbraking. Both dead hooked and booked. My fiance went along and brought a glass of water, she was wearing it after the first test hit.
Since then I fixed the bypass from not sealing (about 8.5-9.0 psi now), moved the HX a bit and got the IAT down to 120 (with 100 ambient temps), and bumped the timing to 16 degrees.
I am planning on going to the track either this month or October.
