1995 sleeper truck 6.0
Old 10-15-2018, 05:27 AM
  #161
SCOTT_A's Avatar
Default New Personal Best 1/4 Mile
All summer I have been trying to hit my 1/4 mile index of 12.50 seconds and haven't had time to see what the truck can run flat out. Below is a slip from 2017 when the DA was -500 feet (left). The slip on the right is from last Friday night when the DA was -100 feet. The only mods from the slip on the left and the right is 4.30 gears (previously 3.70), 100 pounds of weight loss from the 4-link and the air box listed a few posts back. The 60 foot dropped a tenth and MPH is up as well.
The only mod I have planned for this winter is a TBSS intake and 90mm throttle body. I've been skeptical if this intake is worth what everyone says. We will see this spring.
T-RevMotorsports (03-27-2024)
Old 11-03-2018, 10:12 AM
  #162
bruno17's Avatar
Love the truck
Old 01-28-2019, 09:09 AM
  #163
SCOTT_A's Avatar
Default 2019 Winter Work
Quick Update. TBSS/NNBS intake, 90mm throttle body and 36 pound/hour injectors. I made a new aluminum intake tube due to the throttle body being in a different position. This is the only change to the setup this winter. Looking forward to spring to see what improvements this will yield at the track.
Old 01-28-2019, 03:01 PM
  #164
hunterbohanan23's Avatar
Setup looks awesome! Wish I had your skills on suspension. I'm working on a 96 c1500. Lowered it a few weeks ago at 4/6 and picked up some adapters to run camaro ss wheels. Nice sporty look. Powerplant is a ls3 so it should run good. Keep this thread going so I can stay motivated
Old 01-29-2019, 03:28 PM
  #165
Vortec350ss's Avatar
Everything looks awesome!
I can't wait to see how this performs.
Old 06-08-2019, 07:21 AM
  #166
SCOTT_A's Avatar
Default TBSS intake results
Below on the left is the quickest time I achieved prior to the intake swap. This is with the stock LQ4 intake manifold, throttle body and 8.1 truck injectors (running 100% duty cycle). The density altitude was -100 feet.
On the right is after the TBSS intake, 90mm throttle body and 5.3 Flex Fuel injectors (running at 85%). The density altitude that run was +600 feet. No other changes were made, truck is the same weight, same tires, etc. It certainly lived up to the hype surrounding this intake, picking up ET and MPH.
This will help this season of Outlaw 10.50 index racing when I need to hit 12.50 in the heat of summer. I should be able to run my index in the hottest of New Hampshire summer days with this change. Can I hit 11.99 this fall when the DA hits -1000 feet? I'll find out in 4 months.
Old 01-02-2020, 05:43 PM
  #167
Registered User
Js-85c10's Avatar
Default Gauge bezel
Originally Posted by SCOTT_A
Sure, I can get you those... I have a complete set of prints. It was drawn years ago with AutoCAD and that program has been mostly phased out. Do you have access to AutoCAD or should I mail you paper prints?
I seen where u made your own gauge bezel I have a 95 z71 I’m doing a 6.0 in would like to talk with you for a min and maybe see if you send me the dimensions on it My number is 931-993-5211 my name is J.J. please message me at anytime at your convenience
Old 01-02-2020, 10:26 PM
  #168
Custm2500's Rude Friend
1FastBrick's Avatar
He posted a PDF with all dimensions in this post below. I have re-attached the PDF in this reply.
https://www.performancetrucks.net/fo...6/#post5448536
File Type: pdf
Old 01-03-2020, 10:30 AM
  #169
arthursc2's Avatar
Received 1,435 Likes on 1,062 Posts
I seen where u made your own gauge bezel I have a 95 z71 I’m doing a 6.0 in would like to talk with you for a min and maybe see if you send me the dimensions on it My number is xxx-xxx-xxx my name is J.J. please message me at anytime at your convenience
J.J., welcome to the forum. I hope you got the info you've needed this far!
Hey man, bad idea to post your number on a forum that isn't private. All it takes is one google bot or one bored dick head and you have a lot of **** calls/texts to worry about
Old 01-03-2020, 11:32 AM
  #170
Registered User
Js-85c10's Avatar
Default Gauge bezel
Yea you probably right lol where did u get your indicator lights
Quick Reply: 1995 sleeper truck 6.0
