1984 K5 Blazer
Old Feb 24, 2021 | 07:48 PM
  #321
Bgbldodge's Avatar
Oooo shiny.
Old Feb 25, 2021 | 01:47 PM
  #322
Bgbldodge's Avatar
And just ordered the 383 rotating assembly. Now to drop the block off and wait for the rotating assembly to ship.
Old Feb 25, 2021 | 01:49 PM
  #323
dantheman1540's Avatar
Wait did you pull the motor? Or you find another motor to build?
Old Feb 25, 2021 | 02:06 PM
  #324
Bgbldodge's Avatar
I bought a 97 vortec a year and a half ago with intentions of building it to install in to something one day. Factory roller with a one piece rear main. Then I bought the blazer and all my engine money went towards that. Blazer is in a good spot mechanically now so it's time to build the spare block and drop it in. The current motor is bored 60 over with flat tappets and a two piece rear. Stock build with an RV cam. It runs fine but the oil pressure is about 2-3psi at idle but climbs to about 30psi running down the road. I don't know the history of this engine but given the bullshit I've had to fix from the previous owner I'm going to scrap it and start with a fresh engine. Current plan on the new motor is flat top pistons, brodix ik aluminum heads with 180cc runners and 70cc chambers and a howards cam with 560ish lift and a 112lsa. Should be about 10.1:1 compression and make solid power from about 2000-6500. Throw an 11" converter with a 2500 stall in the transmission and this should be a fun truck to bomb around in but still be able to crawl. I'm also starting to piece together a Holley Terminator X fuel system hence the new intake manifold.
Old Feb 25, 2021 | 03:18 PM
  #325
tjmath's Avatar
Ohhh that sounds like it will work real nice in there.
Old Feb 26, 2021 | 07:53 AM
  #326
Yikes 2-3 psi OP is scary, sounds like it will be a ripper with the new motor! I'm all about having spares or at least a solid plan on backup engines and trans, sick of waiting for stuff to get finished at shops when I need it or trying to find stuff in stock during the covid BS.
Old Feb 26, 2021 | 09:10 AM
  #327
Bgbldodge's Avatar
Pressure builds up with rpm’s so I’m not terribly worried but I always have that thought in my mind of when it pops. It might be loose bearings, might be a worn pump, who knows. Not worth risking with a big build. I’ll tear it down when I put the new one in and see if anything stands out and maybe throw some
bearings at a pump at it and leave it for a spare or sell it.
Old Feb 26, 2021 | 09:41 AM
  #328
arthursc2's Avatar
I like the new signature! #TeamNotACrawler
Old Feb 26, 2021 | 09:53 AM
  #329
Bgbldodge's Avatar
That signature has been around for a while now haha. I just rarely post from a computer. And it’s not a full on crawler haha.
Old Feb 26, 2021 | 10:57 AM
  #330
arthursc2's Avatar
I only see it when I am on the computer and Im not on the PC very often, mainly phone. No sigs on phone
