1500 RCSB LLY round 2
Old Dec 22, 2014 | 10:41 PM
  #91
thunder550's Avatar
High on diesel fumes
I think I'm going to skip them. The upper one would fit, but the two lower ones won't.
Old Dec 26, 2014 | 12:55 PM
  #92
cooter1989's Avatar
Very well done sir
Old Dec 28, 2014 | 10:21 AM
  #93
thunder550's Avatar
Originally Posted by black00chev
Everything looks badass man!
Maybe I missed it, but what turbo is the new one?
It's a BW S475. Makes a nice whistle
Spent the last few days dealing with a cracked trans cooler in the radiator. Had coolant in the trans and trans fluid in the cooling system. This is what I drained from the trans:
Talked to Mike L, he walked me through the flush procedure. A new radiator and 24 gallons of trans fluid later, it was coming out clean
In case anyone is curious what 24 gallons and $500 in trans fluid looks like, here you go:
Put a few miles on the truck yesterday, everything seems to be running fine. I think I may have dodged a bullet.
Still working on flushing out the cooling system. Flushed with 1/2 qt of Simple Green and water 3 times yesterday, and once with a cup of Tide detergent and water. Smelled laundry fresh when I dumped that one, lmao. I was still getting little oil droplets coming out, so I refilled with water and a cup of tide again, going to run it for a few days and drain and refill again until there are no oil droplets left, then flush with straight tap water, then straight distilled water, then finally fill with distilled water and Dexcool. I think the cooling system flush will be an ongoing thing for the next couple of weeks.
Old Dec 28, 2014 | 11:28 AM
  #94
1FastBrick's Avatar
Custm2500's Rude Friend
Ouch...
So you had to replace the radiator too?
Old Dec 28, 2014 | 11:32 AM
  #95
BlackGMC's Avatar
Resident Retard
damn, that is alot of tranny fluid!
So what is the benefit of doing twins on a duramax? More boost? Quicker spool?
Old Dec 28, 2014 | 11:38 AM
  #96
thunder550's Avatar
Ouch...
Yep the cooler in the radiator was leaking so the two were mixing.
More boost. The stock turbo runs out of steam pretty quick at higher rpm. With the compound setup you get the quick spool of the stock one and the higher top end of the 475. I'll go from 30-35 psi to somewhere around 55psi with the new setup.
Old Dec 28, 2014 | 11:40 AM
  #97
1FastBrick's Avatar
What did you replace it with? Auto parts store brand?
Old Dec 28, 2014 | 11:58 AM
  #98
thunder550's Avatar
Got one from Performance Radiator here in Phoenix.
Old Dec 28, 2014 | 01:37 PM
  #99
GM1697's Avatar
After all that, I would have just stuck with a stand alone for the trans.
Old Dec 28, 2014 | 01:50 PM
  #100
BlackGMC's Avatar
Resident Retard
What kinda power is at 30-35 vs 55psi?
