14 BOLT BUILD (mucho pictures)
Old 02-14-2011, 11:55 PM
  #21
I have a gauge for that
Atomic's Avatar
Fine. Im changing my vote to the flexplate then.
Old 02-14-2011, 11:57 PM
  #22
EVILGMC's Avatar
already broke that once...updated to the latest GM design.
Old 02-14-2011, 11:58 PM
  #23
Atomic's Avatar
How about that bezel around the tailgate then. Those damn things are flimsy as ****
  #24
Custm2500's Rude Friend
1FastBrick's Avatar
Originally Posted by Dezert1500
Joseph you really spent a lot of time on that axle. It turned out really nice, you should start making these for other people. I was curious on how you set up the axle jig to keep the axle straight after welding. Very cool idea how you machined down those outer supports for the main bar in the middle.
Hey matt, Hows the newest set up working out???
FWIW
I used a 2'' solid lineup bar Just like any housing that would get narrowed. I used to do alot of 9 inch housings. No one make's a set of pucks that fit the 9.5 So I had to order a new set for a Dana 60 and machine them down. Normally at the end there would be a puck that slides in the tube to help keep it straight while welding on it. In this case I not only had to hold the tube but I had to keep the Brake flange straight durring welding.
I used a freind of mines shop to do all the prep and fabriction. I also machined anything that needed maching there. The only thing not done by me was the welding. Not because I can't but because I wanted the best looking weld on Pats stuff and don't often weld any more like I used to do.
Old 02-15-2011, 12:00 AM
  #25
EVILGMC's Avatar
shaved tailgate. bitch.
Old 02-15-2011, 12:02 AM
  #26
1FastBrick's Avatar
Atomic, Arent you about do to blow another motor???
Old 02-15-2011, 12:04 AM
  #27
2004SSS's Avatar
you going to try it out at fontucky? looks awesome i like this option better for the positioning of the caliper alone . nice work guys!!!!
Old 02-15-2011, 12:05 AM
  #28
Baltimore Whore
Mangled03gmc's Avatar
Great looking fab work for sure. Can I ask though why didn't you just go with a 9'' if you had to do all that work??
Old 02-15-2011, 12:07 AM
  #29
EVILGMC's Avatar
being stubborn...wanna keep it GM. I don't plan on changing ratios often and a nodular 3rd member (w/gears and center) costs more than I have in this whole thing.
Old 02-15-2011, 12:08 AM
  #30
EVILGMC's Avatar
gotta bleed the brakes tomorrow and do some road tests. if all goes well this week, i'll do the private track day.
Quick Reply: 14 BOLT BUILD (mucho pictures)
