04 Z71 Daily Driver Slow Build Up
#41
I you want a nice bump in height and not turn your bars up any more. You can always go with a 1.5 body lift for pretty cheap. You can't even tell their on the truck. I've put them on current truck my last truck.
#42
Theres been several TVS setups sell for under $4k on here. The TVS 1900 I bought a few years back was well under $4k and came with everything needed besides fuel injectors and pump.
Nice truck I like the big tire no lift look.
#43
Thanks for the compliment on the looks, Im a fan of it as well, so keeping it lower with a slight bump in tire size, it helps to keep it practical but still big.
#46
I am not a cam expert whatsoever but If your looking to eventually put a blower on there are some good cam choices that will work well NA and compliment a blower later. The 212/218 112lsa high lift cam I have in my 6.0 Tahoe is great NA and is actually the same cam specs I was going to run in my RCSB when it was at 16psi just a different LSA to move power higher into the rpm range. Since you have big tires most guys will probably recommend a similar mild cam. In a 5.3 I think it would still be stock converter friendly and sound nice at idle while also working well supercharged.
#47
Still in school, just finished Junior year at App State. Went up to a 315, played with the torsion bars and leveled it out some. Went full 3 inch exhaust, same Borla muffler, and it's dumped over the rear axle. Less drone, more noise.
Went with drilled/slotted rotors, the 08 up fronts and factory style rears. LEDs up front for dogs and highs, HIDs for the low beams.
Have been talking with the wife about selling/trading the truck, but going to keep it, and in doing that it's going to get a 6.0/4L80e. I'm starting to worry about my transmission. Going to add boost, and leaning more towards a SC. LSA or TVS is high on the list. Wife wants something smaller than her Suburban, so the Burb will be a third vehicle/road trip car, so will get a few things for better mpgs and entertainment for the kiddos.
For work, I'm going to take over a new store, so a place to put it all together and in. I'm probably going to buy a new trans (not a transmission guy, will swap but not interested in opening one up honestly), one built by a reputable builder (i.e. not monster) and have been reading a lot about the swaps, especially the 4WD swaps and the transfer case is the biggest question. I've seen some where some swap inputs/outputs, and I think I saw one where they just swapped the case completely.
For wiring, would it be easier to swap the whole harness, since it's all going to be out, or just repin?
#48
I would just do the repin, its easy and cost nothing to do.
