This is one of the rarer cases that I think a centri is the appropriate answer, if a turbo build is off the table
I cant comment on the gearing. I want more gear, or a 6L swap. My poor Tahoe is a dog off the liine
The only reason I’m choosing not to go turbo I already have a turbo car and it quite a bit more work and monies, I don’t wanna push higher then 8 psi considering the motor is higher on the compression side
I need some opinions on carrier setups I talked with some rearend suppliers and they suggested a Yukon dura grip for my application considering its more aggressive on locking the rear up and the clutch elements are replaceable compared to the tru trac, yes the tru track ls more quiet but doesn’t lock the rear nearly as well and with the dura grip he said would throw in upgraded clutch springs to reduce the wear under hard acceleration.
I have a Tru Trac in the front of my Toyota based crawler. Its been in there since ~2007 and it has seen a lot of abuse from the PO, who is a buddy of mine so Ive been there for a lot of the abuse. I havent abused it at all yet
Its damn near open at this point. She will unload when I try to drive it up the trailer at an angle without ramps. I dont know if that speaks to its durability and ability to survive abuse, or if that means its a POS
Same truck has a Detroit in the rear and Im a fan
The truck in question also has a whopping 43.1hp, so lets not get carried away
The Denali Decided it wanted a new rear end sooner then anticipated, Spider gears are smoked Luckily the ring and pinion look fine and i was able to drive it home. Detroit true trac should be coming in the next few days with some other goodies.. Definitively missing some teeth here. yummy metal bits.
Parts all laid out for the install spider gears are so destroyed they just fell out gear lash within spec, no spacer adjustment needed Bling Bling mesh pattern check, I am by no means a expert but when using used gears the coast pattern is more important
has not been howling or blew up so ill call it good
