03 SS awd turbo street build
Old Apr 8, 2018 | 09:12 PM
  #151
SDjeff619's Avatar
Default Dual Waldron 450 pump install
finally got a good deal on an 04 fuel tank and bucket so I moved forward with the dual wall to 450 pump install with Racetronix parts and harness w/ 4psi Hobbs switch.
The 3 way air fitting with a 1/2” npt and 3 1/4” npt inlets with 1 plugged.
But there isn’t the best of flow for the inlets so I drilled them out for optimal fuel flow.
The 450’s with Walbro rubber sleeves. I have to sand down the rubber on the left sleeve to fit in the smaller portion of the pump housing in the buckets.
Stagger install.
Unpinned the two purple level sender wires and snap right into place on the racetronix dual pump harness and plugs into the Racetronix bulkhead plug through the top hat.
Here’s the Racetronix supplied bulkhead plug.
End result with gates green shield hose.
-10 AN bulkhead fitting welded up.
Old Apr 9, 2018 | 02:24 PM
  #152
BudRacing's Avatar
Nice work. That's a massive bulkhead fitting. That system should have plenty of headroom.
Old Apr 10, 2018 | 10:14 AM
  #153
Sevex's Avatar
Snail Fab
Wheels Look great!! did you get tires through them as well?
Old Apr 10, 2018 | 06:18 PM
  #154
SDjeff619's Avatar
Thanks Bud.
I did get the tires and wheels mounted and balanced through them.
Old Apr 11, 2018 | 12:36 PM
  #155
Choda's Avatar
How much do you want to build me a fuel bucket assembly exactly like yours?
Old Apr 11, 2018 | 01:03 PM
  #156
ILuvJDM's Avatar
If I'm understanding the install correctly, you used one red and one blue for power wires to the pumps. One will be on with the truck, the other on a Hobbs switch. Then you spliced both pump grounds and connected to a stud on the hat which you will then carry out to the frame once it's installed?
Did you get a hotwire kit or do this all yourself?
Old Apr 11, 2018 | 11:23 PM
  #157
SDjeff619's Avatar
Would be supplying all the parts?
JDM, the power/grounds are Racetronix dual pump harness p/n DP-ITWH-029. But To answer your question, yes that’s how it’s set up.
Old Apr 11, 2018 | 11:25 PM
  #158
SDjeff619's Avatar
Old Apr 11, 2018 | 11:27 PM
  #159
SDjeff619's Avatar
The Tuetrac, Redline shockproof, Yukon master kit and TA cover came in today for the rear end.
Old Apr 12, 2018 | 12:24 PM
  #160
Choda's Avatar
Originally Posted by SDjeff619
[left]
No, i think it would be best for you to order/build as you have with your own. You know what parts are needed.
