01 sierra turbo build! new frame
Old Jan 8, 2011 | 06:37 PM
  #171
vicalma03's Avatar
Thanks for the comments!! Heres a little update! Installed the E-fans!!! That is all.....
Old May 1, 2011 | 10:24 PM
  #172
vicalma03's Avatar
Small update. transgo hd2 installed, circle d converter installed, fans wired, Dp installed and muffler installed.
Old May 3, 2011 | 12:41 PM
  #173
vicalma03's Avatar
Finished up the cold side piping.
Old May 3, 2011 | 01:04 PM
  #174
Steve-O-08's Avatar
That build is awesome! Great job. Really looking forward to the finished product.
Old May 3, 2011 | 03:27 PM
  #175
vicalma03's Avatar
Thanks! I'm hoping to have it running within the next two weeks
Old May 3, 2011 | 07:57 PM
  #176
skyhighsami's Avatar
no title here
Why did you ditch the Wilwoods?
Old May 4, 2011 | 03:04 PM
  #177
vicalma03's Avatar
It was going to take a little bit of fabrication to get them to work with the rear end. The brackets I need to make where gonna be a little to expensive to so I decided to go with this set up instead and just save up for a big brake kit.
Old May 13, 2011 | 11:42 PM
  #178
vicalma03's Avatar
Ok so I'll be starting the truck up tomorrow for the first time in 5yrs!!! I pretty much have everything ready. I had a -4 feed line made, used 5/8 line for the drain and drilled/tapped the front right side corner of the pan. I still need to fill the truck with all the fluids, mount the radiator overflow tank and connect the water/air intercooler to my tank and pump. Does anybody know what kind of trans fluid to use with my 05 80e?? I'll post a vid as soon as it fires up. Hope I dont run into any big issues.
Old May 13, 2011 | 11:50 PM
  #179
AKlowriderZ71's Avatar
11 Second Hall Moniter
Dexron VI, and congrats on the near completion!
Old May 13, 2011 | 11:53 PM
  #180
vicalma03's Avatar
Thanks! I'll be adding dexron VI to my autozone list.
