01 sierra turbo build! new frame
#177
It was going to take a little bit of fabrication to get them to work with the rear end. The brackets I need to make where gonna be a little to expensive to so I decided to go with this set up instead and just save up for a big brake kit.
#178
Ok so I'll be starting the truck up tomorrow for the first time in 5yrs!!! I pretty much have everything ready. I had a -4 feed line made, used 5/8 line for the drain and drilled/tapped the front right side corner of the pan. I still need to fill the truck with all the fluids, mount the radiator overflow tank and connect the water/air intercooler to my tank and pump. Does anybody know what kind of trans fluid to use with my 05 80e?? I'll post a vid as soon as it fires up. Hope I dont run into any big issues.
