01 sierra turbo build! new frame
Old Mar 23, 2010 | 09:29 PM
  #91
1FastBrick's Avatar
Custm2500's Rude Friend
Is some one helping you set up the Ladder bars??? I Know it probally comes off a little rude and I appoligize if it does. I just want to make sure your intersect points are set up correctly before you get the whole thing finished.
Also what brand alignment bar did you use in the begining on the first housing?
Old Mar 23, 2010 | 10:50 PM
  #92
vicalma03's Avatar
No I'm doing it on my own. The line up bar is made by Mark Williams.
Old Mar 23, 2010 | 11:02 PM
  #93
1FastBrick's Avatar
Mark Williams Is good stuff. Mine is very similar to theres only I custom ordered a longer bar. I have there pinion bar too but I had to put a longer tube in it to be able to use it on regular vehicals.
Old Mar 24, 2010 | 11:56 AM
  #94
vicalma03's Avatar
Nice. I bought it a while back from a buddy that got it from a auction. The best $100 I've spent. It was new in the box too.
Old Mar 24, 2010 | 09:08 PM
  #95
1FastBrick's Avatar
How did you determine were your intersenct points needed to be for your front latter bar brackets???
Old Mar 25, 2010 | 12:47 AM
  #96
vicalma03's Avatar
I set the ladder bars up per the instructions from quartermax. Basicaly leveled the truck at ride height, centered the rear pinion with the CL of the chassis, mounted the ladder bars on the 2nd hole of the ladder bar brackets and made sure the lower ladder bar links were parallel with the ground. The ladder bar brackets I made are a copy of the brackets that were sent with the kit, I just redesigned the bracket to work with my frame.
Finished up the DP.
Old Mar 25, 2010 | 04:36 PM
  #97
phasemaster1's Avatar
So thats how that 4"dp is going to fit.
Old Mar 25, 2010 | 10:26 PM
  #98
vicalma03's Avatar
Yes sir, I finished up the hot side tonight. The front end is back on and I'm going to start on the wiring harness tomorrow.
Old Mar 25, 2010 | 11:17 PM
  #99
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Only single shear on the rear coilovers?
Old Mar 25, 2010 | 11:40 PM
  #100
LsxCody's Avatar
its coming along nicely
