{Project} White Noise- 2005 ECSB 2wd Silverado, Forged 402/4l80e/PTE 88mm turbo
#52
Fuel Injector Calculator from WitchHunter Performance
RC Fuel Injection
#53
hmm every chart i show online said around 997cc at around 43.5psi for a 95lb per hr injector
RC Fuel Injection
RC Fuel Injection
OP, my 850cc injectors were at 85% IDC on the 578hp pull. I'm on E85 so as long as you are running meth, I think the 1000cc injectors will get you to your goal.
#54
so running more pressure makes the injector smaller?. 95lb per min is roughly 1000cc thats at 43.5. bumping pressure to 58psi would technically make it like a larger injector
if yours were 850cc they prob were not 95lbs per hour as 850cc shows equivalent to 80lbs per min
#55
Where are you getting your logic.... FIC rates there injectors at 3 bar (43.5psi). So I bought 850cc injectors at 3 bar. I run those injectors at 4 bar pressures, making them flow more fuel. So they are really 93.5lb/hr injectors. If the OP buys the 1000cc injectors then they flow 95.2lb/hr at 3 bar (43.5psi) and 109lb/hr at 4 bar (58psi)
#58
Yea now i realize what you are talking about. Originally you said why not buy my 95lb per hour injectors and then he said 850cc was to small
So i was just stating that 95lbs per hour is roughly 1000cc not 850cc. I think we just pretty much both confused eachother yet we are on the same page lol
