**Three6GMC Official Build Thread**
#782
This is where im at right now as im waiting for more parts... Cold side is done and most of the hot side. I still need to run the intercooler lines, finish the crossover and figure out what I want to do with the downpipe. I could have had all that done BUT got sent the wrong transition pipe so codlin get that done these days off. Next days off hopefully everything will be in and ill have this truck finished up and fired off.
#786
What does your fuel system consist of now? I'm thinking of going with the sump like that to keep from hacking up a stock pump. If you slam on the brakes or corner hard will the pump lose it's prime or does it have a baffle in it?
#787
Walbro e85 450 in tank and a 4303 frame mounted... the sump has a hat inside that would keep fuel in it for a quick second but to be honest you would have to have the tank damn near empty to run into any issues. I run the same sump in the single cab and have been below a 1/8th of a tank and didn’t have any issues.
#788
Does the single cab have a pump in the factory location also?
