7.3L power estimate?
Old May 10, 2008 | 11:40 PM
02 7.3L's Avatar
Registered User
Default 7.3L power estimate?
Can any one tell me how to calculate rear wheel hose power. I have an 02 7.3 with a super chips programer, AFE stage 2 intake, 4" turbo back exhaust. What is the power out put and what would a bb turbonetics turbo with a stage 3 snow performance methanol injection ststem add?
Old May 12, 2008 | 10:33 PM
JakeBrakeIH's Avatar
well with a superchips in not gonna be much thats for sure...take it out and use it as a paper weight...to wake up the 7.3s the best chip is DP tuner with out a doubt!...I put one in on my friends 99 and night and day between the bully dog he had...
as far as the turbo goes, its not needed unless you do a large chip along with injectors...you need fuel to make boost so without either a chip or injectors it will do the same as your stock turbo...
the menthol injection is really used to keep EGTs down along with added power...but then it comes down to your turbo...add more fuel, get more air in there...
your going along the right track with your intake and exhaust but just get a different chip and you will be MUCH happier...the guys at DP tuner will custom burn you a chip to want you want and are easy to work with...
Old Oct 27, 2008 | 10:05 AM
02 7.3L's Avatar
Registered User
I agree with the DP tuner. I switched from the superchips and am much ahpper with the power output and switch on the fly. I also have water meth. It is ok but expensive for the power gains you get. It does lower EGT by 100-150 degrees for me when towing. MPG was relatively unchanged with the water meth kit. I like my turbonetics BB turbo as well. You can hear it still spinning even after you let up on the accelerator. It is a very efficient product. Consider the intercooler if you do the turbo.
Old Oct 27, 2008 | 10:08 AM
02 7.3L's Avatar
Registered User
If you want power you should look into the next step up injector from alliant that is a single stage injector as opposed to the dual stage injector that is stock. International used a single stage ho injector whick will increase mielage and add about 20 HP. It is best to decide how much power you want then buy the parts as your tuner will have to be programmed appropriatly. Power is adictive.
Old Dec 20, 2008 | 07:11 AM
gmc6's Avatar
get a custom tune to help out with your mods.
Old Dec 8, 2009 | 03:09 PM
Synister's Avatar
I had a 2000 Power stroke with a turbonetics, MBRP 4" exhaust, S&B intake, and an edge evolution and I made 386hp at the tires. hope that helps give you an idea of the power you would make
Old Dec 8, 2009 | 05:47 PM
viciousknid's Avatar
Where's the Beef?
Is he offering advise to himself in his own thread?
You know this is over a year old right?
Old Dec 27, 2009 | 01:14 PM
stoffer's Avatar
I paid my buck-o-five
andrewlong
Nov 9, 2016 09:38 AM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
Superman09
Sep 25, 2015 05:55 AM
Brandonlflr12
Sep 9, 2015 03:54 PM
