Xlink problems
Old Sep 11, 2014 | 03:30 PM
06bluchevy's Avatar
Ya now that I know that the green wire doesn't go through the link I conceded that it is not that issue.
As far as spark I have added almost 12* down low (where it was only about 4*) from what I had on motor because I believed that it may not have enough. The issue still persisted.
Burst Knock is still enabled.
As for being afr, it may be very fat. As it has a .028 nitrous and .014 fuel pulling off rail in the direct port. As you can see the lambda is as low as .69 in first in the run.
Old Sep 11, 2014 | 05:02 PM
DrX's Avatar
DrX
It wouldn't hurt to log burst knock as well because it looks like some timing is pulled.
Old Sep 12, 2014 | 04:03 PM
06bluchevy's Avatar
Ok. Well now I'm back to not being convinced its not something to do with the x link. This is a log pulling off the APP sensor 1 prior to the tac. The truck sprayed but the throttle itself never opened to 100%. I also could also tell it never went above 50% due to the short shifted first and MAP.
Old Sep 12, 2014 | 04:04 PM
06bluchevy's Avatar
Log file:
File Type: hpl
Old Sep 13, 2014 | 09:02 AM
DrX's Avatar
DrX
Don't see what the commanded TP was. If actual TP and commanded TP do not match REP mode will be triggered, a code(s) will be set and the throttle will be disabled. Log ETC Desired Position % and ETC Position %.
madmann26
Apr 29, 2020 09:17 AM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
sTNT971
Sep 26, 2015 06:27 AM
