Window switch question & another
Old Dec 18, 2005 | 12:52 PM
Default Window switch question & another
Hey with the window switch set at 2500-4800rpm and it shifts a 4900rpm as soon as my rpms drop down below 4800rpm will the nitrous turn on again and spray through the shifts- or does it wait for it to engage into gear- Thanks
ALSO where can i find nitrous solenoid brackets/mounts- i need some (x2)
Old Dec 18, 2005 | 04:06 PM
goshawk23's Avatar
Truck addict
to answer your first question yes. however if you have a stock tranny i would give it at least 200 rpms for a shift. so instead of closing the window at 4800 i would do it at 4700.
what are you driving that shifts that low?
one of our sponsors sell the brackets and mounts.------------------------->
Old Dec 18, 2005 | 07:30 PM
i have a 2002 blazer 2wd 4l60e 4.3L-
O YEAH I CANT FIND A MOUNT FOR THE COLD FUSION SOLENOIDS ANY WHERE PLEASE HELP!
Old Dec 18, 2005 | 08:07 PM
goshawk23's Avatar
Truck addict
since your using CF noids give it till morning time and i am sure nitrous direct will chime in and fix you up. our two nitrous sponsors are good people always willing to help.
Old Dec 19, 2005 | 02:53 AM
Robert56's Avatar
I agree with what Goshawk said on the WS. Custom mounting brkts, Nitro Dave is about the only one who has those, for the time being.
Robert
Old Dec 19, 2005 | 11:32 AM
Nitro Dave's Nitrous Outlet's Avatar
LS1TECH & TRUCK Sponsor
WE carry solenoid mounting brackets.Here is a link.
http://www.nitrousoutlet.com/outlet/...section_id=140
Old Dec 19, 2005 | 01:17 PM
Silver-Dollar's Avatar
So are you saying, in this case, once the rpms drop below 4800, the solenoids is energized again? If so, then it will be spraying through part of the shift. I guess the only way not to spray through any part of the shift is to manually engage/disengage the nitrous system.
Old Dec 19, 2005 | 01:46 PM
southern_chevy's Avatar
Correct me if I am wrong but my understanding it it will not open the solenoid till the begin rpm is reached after the shift. Like I said correct me if I am wrong.
Old Dec 19, 2005 | 02:22 PM
Robert56's Avatar
If you don't want to spray through your shifts, set high point for a little below your shift rpm setting, then you'll save wear/tear on tranny.
Robert
Old Dec 19, 2005 | 11:12 PM
will those fit any solenoid mainly CF? or do they only fit NX solenoids?
