where else can i hook up my window switch beside pin #10
Old Dec 4, 2011 | 11:14 PM
joelm86's Avatar
Default where else can i hook up my window switch beside pin #10
where else can i hook up my window switch beside pin #10, i was told i could hook it up some where passenger side fender connector or some thing like that, i already have my shift light hooked up to pin number 10. any other place that would be the same as hooking it up at pin number 10. and pictures would help greatly.
Old Dec 4, 2011 | 11:26 PM
Atomic's Avatar
I have a gauge for that
What is pin number 10? A source, ground, etc...?
Old Dec 4, 2011 | 11:33 PM
joelm86's Avatar
pin #10 out of the ecu (tach output), thats what the instruction say.
Old Dec 4, 2011 | 11:38 PM
Atomic's Avatar
Oh....can you not still use that wire and share with the shift light?
Old Dec 4, 2011 | 11:44 PM
joelm86's Avatar
wanted to hook some where else, instead of sharing a wire. wanted to see if any one was running it a little diffrent
Old Dec 6, 2011 | 10:31 AM
LS1TRUCKGUY's Avatar
What year is your truck? 99-02 you can tap into the white wire behind the gauge cluster, you can also tap into a wire on one of your coils. I forgot which one though. Do a search. There's plenty of info out there
Old Dec 6, 2011 | 12:22 PM
brandon6.0's Avatar
i have read of people using the coil ground or somethin for an activation also. Search it.
Old Dec 7, 2011 | 09:37 AM
joelm86's Avatar
cool thanks guys im going to put it on passanger side coil pack that should work.
Texas5.3_1251
Mar 5, 2016 08:10 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
Closer_2001
Sep 24, 2015 09:15 PM
kalikid06
Sep 20, 2015 07:46 PM
