what wrong with TR6's?
Old 08-10-2011, 12:21 AM
  #21
SILVERADO11's Avatar
Originally Posted by TX Tahoe Z71
Right now, I am using the projected TR6, mainly because I didn't know the benefits between projected and non until now.
It runs fine, starts up every time, and pulls strong, but it is also the only type of plug I have run with the blower, so I don't have any basis for comparison.
X2, may have to look into the none-projected for the future plug change.
Old 08-10-2011, 12:45 AM
  #22
11 Second Hall Moniter
AKlowriderZ71's Avatar
The reason you would use the non-projected tip is this.
Forced induction & nitrous setups have highly increased cylinder pressures, with more fuel being burned per revolution. The spark plug electrode hanging way down there in the combustion chamber "can" end up getting so hot that it effectively becomes a "glow plug", thus pre-igniting the fuel charge. This is detonation, and you all know what that causes.
Non-projected tips are safer for this reason alone. The colder plug also "pulls" more heat off the electrode, which helps also. But when you go too cold of a plug, you introduce daily driveability problems.
I recommend non-projected tip plugs for 100 shots or bigger, and 5 psi or more. Reading the strap "color-change" will help you determine heat range. Typically, the more cylinder pressure & fuel you're burning, the colder plug you'll need. But it's ultimately up to you to read your plugs, and datalog your runs, to find out what your own combo wants(needs).
Old 08-12-2011, 11:02 AM
  #23
Moderately Differentiated
dewmanshu's Avatar
I just bought the #3346's. Since i need to replace my plug wires because they thought touching the header was okay I am gonna swap from the projected TR6 to the non-projected TR7. I am guessing those colder f'ers will ruin my awesome 10MPG.
Old 08-12-2011, 11:45 AM
  #24
Dewey, what size pulley are you running on your TVS, and how much boost are you seeing? I don't really know anything about your setup...
lucas287
31
01-12-2021 06:18 AM
dsbodley
11-14-2015 09:46 PM
carid
10-01-2015 09:22 AM
chopperloco
09-28-2015 08:40 AM
Quick Reply: what wrong with TR6's?
