what plugs?
i built a chevy 6.0 and i want to spray 150 to it. i am wondering what spark plugs to run? will the stock ones work?: what do you guys use to adjust timing? will the diablo preditor work. thanks for your help
im running a 50ish shot (jettings a little rich) on stock plugs and its been working great. But for a 150 i would definatly go colder. I wouldnt use the handheld either, they add timing and with a 150 youll need to take some timing out.
how much compression? tr6's are ok, but you would be safer with a non-projected plug vs a projected tr6. i use a br6ef on my 10.6 to 1 5.3. at 11 to 1, i would be at a 2 step colder non projected br7ef plug, all NGK. call daves n2o outlet, and ask them about what plugs to run, and make sure you read them after.
