what needed to run 300 shot
Old Oct 4, 2005 | 10:08 PM
black4x4's Avatar
Originally Posted by Pewter53
then you should have no problem spraying that little of a shot just keep tabs on the a/f keep it real rich and keep your fuel pressure on the rails around 68 for that big of a shot lol these things need no girdles they have 6 bolt mains they are made to run 6600 rpm all day everyday in boat applications. they love nitrous i promise the more the merry is how i look at it you will have a very big grin on your face wehn you get the second stage kicked in. i would go with a 175 out the whole cause that is going to be a hell of a launch trust me on that one to i do it every weekend. and the next 175 shot about the 60 foot and you should be very happy and safe.
I was thinking about 100 or maybe a little more out of the hole cause i plan to run some 265s or 245s with 4.56s at the track my big tires float to much up above 95 or so so it should come out of the hole. as long as i can get a low 13 out of it and if i hit a 12 something that would be the ****.
Old Oct 5, 2005 | 09:15 AM
just keep the fuel pressure when you go to spray don't this on motor alone keep it at bout 68 no more though and keep your fuel trims since i am guess you have a tuner hopefully keep them very rich from about 2800 to where ever you plan on spraying around 6000 or so on that kind of shot.
Old Oct 5, 2005 | 04:11 PM
black4x4's Avatar
so i will need to run even more fuel through the injectors even though i will be running a wet shot?
Old Oct 5, 2005 | 04:49 PM
the reason i am saying running that much is because just because you are using a wet kit it is going to be pulling out of the fuel rail if you do not use a external n2o fuel system . if i was you i would have a go cart gas tank the little gallon ones mounted somewhere under the hood or in the back with atleast 114 octane gas as your n2o fuel supply pulling off the rails with that big of a shot id really going to be pushing it.jegs has them for around $100 i think i really think you should get some et streets or atleast some nittos what kind of tire do you plan on running. street tires are never going to hold that kind of shot i have some pretty sticky tires and my 175 shot and stall make me get sideways for atleast 75 feet from a 60 mph roll. its really cool to ride it out when your racing from a roll people will be scared to race again.
Old Oct 5, 2005 | 09:52 PM
black4x4's Avatar
I had seen the stand alone systemsand had wonderd about them. and i dont think i'll have traction issues i plan to run some 245 or 265 truck tires put it in 4hi and go didn't seem parish had alot of traction issues so i dont think i will.
Old Oct 7, 2005 | 11:27 AM
you shouldn't but im saying you need to make extra sure it locks in 4 wheel drive or you will be goiing for a real ride.
stealthperf
34
Feb 14, 2016 11:35 AM
ZONES89RS
21
Sep 24, 2015 05:58 PM
Bluecollar Hotrods
Jul 16, 2015 08:52 PM
Aboss
Jul 9, 2015 10:28 AM
