wanting to spray with turbo
Old Nov 16, 2009 | 06:30 PM
SLO TRUCK's Avatar
Default wanting to spray with turbo
I am wanting to spray my 5.3 that has a 70mm front mount on it with 10psi, small cam, valve train is upgraded. Looking to spray at least a 75 shot if not a 100. Looking to find out if this is a bad idea or a good one. Also is a nozzle or a plate wet or dry the way to go.
Thank folks
Old Nov 17, 2009 | 06:18 PM
SLO TRUCK's Avatar
I guess no one knows about spraying with a turbo.
Old Nov 17, 2009 | 06:41 PM
kbracing96's Avatar
I just did some trading for a single nozzle wet kit and gonna try spraying mine out of the hole just to get consistent launches and lower 60's. I want to do a little bracket racing next years, so I think a 75 shot on a 3000-4500 window switch will light the turbo and get the job done.
Old Nov 17, 2009 | 06:57 PM
Phantom's Avatar
11 Second Club
I was thinking of doing to the same thing as Kyle when I go back to turbo. I'm thinking a single nozzle wet kit 100shot out of the hole on a controller and ramp it down to 0 by the 300' mark.
Old Nov 17, 2009 | 08:04 PM
SLO TRUCK's Avatar
That's what I really want to do is get my 60's down. 2.1 on slicks aint cutting it. I am running 3.23 gears but still.
Old Nov 17, 2009 | 08:25 PM
custm2500's Avatar
Ph.D. in HUBRIS
You shouldn't have a problem. Main thing to is to make sure your rotating assembly can handle the juice and boost, or just make sure you cut the juice off before making much boost!
Why not put a nice converter in the truck and leave on more boost? Sounds easier then adding nitrous.
If you don't go that route and do a nitrous kit you would probably want to go with a wet nozzle or plate. Smaller shots are just fine on a nozzle but plates are just a nice upgrade. I say we because you already have enough tuning with the turbo so no sense it messing with it event more when you can just run a we system and use jets to control your fuel.
Old Nov 17, 2009 | 08:54 PM
quicksilverado's Avatar
Two step will solve your 60' problems.
Old Nov 17, 2009 | 09:10 PM
SLO TRUCK's Avatar
I was thinking a 3200 stall would be a good upgrade. I am running a circle d tb stall.
Old Nov 17, 2009 | 09:37 PM
charcold-bowtie's Avatar
I would get away from the tb stall. My new set up will have a two step eventually
Old Nov 17, 2009 | 09:42 PM
Phantom's Avatar
11 Second Club
lots you can do to get your 60' down where ya want it...different verter, nitrous, two-step, different gears...pick your poison i think i'll personally try the nitrous with some 3.73s when i do mine again
