TPS wiring help
Old Sep 29, 2007 | 04:06 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Default TPS wiring help
Looking for the wiring diagram for a TPS switch. The switch I have came with a TNT wet kit and is about a year old. I was told it may be a Dynotune switch but I dont know. It is a black plastic box with no writing on it and no instructions. I understand how it works but I cant find the schematic for it. Here's a couple of pics, ignore the black electric tape residue all over the wires. BTW, the yellow wire was hooked up to "85" on my relay, if that helps.
Thanks for the help
Old Sep 29, 2007 | 09:03 PM
03 BLACKOUTSSS's Avatar
sorry man, I don't know enough about it to even BS a post. Good luck
Old Sep 29, 2007 | 10:11 PM
dewmanshu's Avatar
Moderately Differentiated
uh, the "85" is the coil on the relay. + or -. So I am confused by the yellow being on it. The TPS switch for nitrous usually has 2 leads for the solenoids, a +, a -, and the TPS wire. I would guess the white wire is the TPS wire. Black and red are obvious and the other 2 are the solenoid leads. Just a guess though. white is usually a rpm switch too.
Old Sep 30, 2007 | 03:40 AM
1SlowHoe's Avatar
Red=12v
Black-ground
White-Tach signal
Yelllow=?
Green=?
Thats where I am stuck.
Old Sep 30, 2007 | 08:43 AM
dewmanshu's Avatar
Then I'd say the yellow and green are the solenoid negative's (fuel and nitrous I am assuming).
00loudchevy
Dec 3, 2015 05:54 PM
bearden86
26
Nov 15, 2015 03:58 PM
JordanH
Oct 3, 2015 03:59 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Wrecker 426
Sep 30, 2015 09:39 PM
