timing options
Old Jan 5, 2010 | 01:41 PM
fastrt's Avatar
11 Second Truck Club
Default timing options
are most of you running a custom OS with a n2o tune, or are you running a controller? my 06 doesnt have a hole lot of options for the tune unless I have missed something. I was looking into a msd timing twister box. what are you guys running?
Old Jan 5, 2010 | 01:47 PM
BlackGMC's Avatar
Resident Retard
Search for "IAT Mod" on tech... Basically what it does is "fool" the computer making it think the intake temp is 194*, you then change the IAT Spark table to the corresponding row to pull X amount of timing...
You also have a IAT PE modifier that you can update the above mentioned IAT to add/substract fuel....
I will get some pics up in a minute.
Total cost of the mod is <$10, it requires some wire, resistor, relay and a switch.
Old Jan 5, 2010 | 02:06 PM
BlackGMC's Avatar
Resident Retard
Basically this is what alot of the "Timing Tuners" do, so here you go.
Wiring diagram
Resistor sizes to match IAT
9420 ohms = 32 *F - 0 *C
7280 ohms = 41 *F - 5 *C
5670 ohms = 50 *F - 10 *C
4450 ohms = 59 *F - 15 *C
3520 ohms = 68 *F - 20 *C
2796 ohms = 77 *F - 25 *C
2238 ohms = 86 *F - 30 *C
1802 ohms = 95 *F - 35 *C
1459 ohms = 104 *F - 40 *C
1188 ohms = 113 *F - 45 *C
973 ohms = 122 *F - 50 *C
667 ohms = 140 *F - 60 *C
467 ohms = 158 *F - 70 *C
332 ohms = 176 *F - 80 *C
241 ohms = 194 *F - 90 *C
So in the tables below i highlighted 194* so you would use a 241 ohm resistor...
IAT PE Modifier table
IAT Spark table
Thank you, drive threw.....
Old Jan 5, 2010 | 04:28 PM
fastrt's Avatar
thank you sir you are an oak. I looked over here and came up empty, I guess all the good info is over there. beats the hell out of $250+
Old Jan 11, 2010 | 06:10 PM
fastrt's Avatar
well i did it, works like a champ, and totall cost was $1.07. I found a new 5 way relay off a wiring kit I had for a UD blower motor bulletin, and wire and connectors from work, .99 cents + tax for the resistors. went with a 330ohm. set 176 to 194* to -4* from .20 cell all the way across. should I set it at -4 across the whole table? should I add any to the PE iat table? I thought it was for dry shot guys.
thanks again Corey
Old Jan 12, 2010 | 08:56 AM
BlackGMC's Avatar
Resident Retard
I am glad it worked out for you. As far as your PE modifier, i would look at your logs to see what your AFR is doing before messing with that one. Or you could just tune your AFR with jets.
Old Jan 13, 2010 | 08:58 PM
fastrt's Avatar
I need to go to the track and test it soon.....got the itch
Old Jan 14, 2010 | 06:23 PM
krambo's Avatar
https://ls1tech.com/forums/nitrous-o...tor-trick.html
I had this one bookmarked since it was first posted.
Old Feb 9, 2010 | 06:50 AM
Burgundy&TanMan's Avatar
I have the timing twister have had it for 3 years I guess, it's worked well for me you can have an all motor tune and flip the switch for nitrous timing. No not as cheap as the above but it does work also I have verified the timing with a snap on scanner.
Old May 27, 2010 | 03:47 PM
Phantom's Avatar
11 Second Club
thanks again Corey
sorry for the thread did
where did you find your resistors? biggest i could find was 220ohm...
