Timing, nitrous, race gas
Old Apr 7, 2014 | 07:07 PM
Lq4tbss2500hd's Avatar
Registered User
Default Timing, nitrous, race gas
Should i pull more timing?
23 degrees on top with a 230 shot from 3,000 on a window switch full wieght 2500hd 6.0 12.38 @ 111mph (stock stall) pulled hard the whole track, no knock detected
I run 93 pump gas always, if i add 110 or c-16 to my tank will it affect my factroy o2 sensors? Would it be worth the cost over the benifit?
Old Apr 7, 2014 | 10:11 PM
dirt track racer 81's Avatar
Run a stand alone fuel cell with c16. Yes you need to pull more timing.. Do alot of reading on yellowbullet.com in the nitrous section on reading plugs. What plugs are your running?
Old Apr 7, 2014 | 10:15 PM
gamble686's Avatar
Really work on reading the plugs. You would be surprised how often nitrous builds will go faster on a little less timing.
Old Apr 8, 2014 | 10:19 AM
NitrousExpress's Avatar
Former Vendor
^^^ What he said, We have seen several instances that you can speed up even with lest timing. Also I would not really recommend running c16 or any leaded gas if you are running factory O2 Sensors. The gas will eventually damage the sensors. Like Dirt track racer said most people use a stand alone with higher octane gas. That way you only spray the high octane when you are spraying and it will not affect your O2 sensors near as much.
Trey
Old Apr 8, 2014 | 10:23 AM
TXsilverado's Avatar
or a leaner tune up. most jet charts are on the rich side (for a good reason).
Old Apr 12, 2014 | 09:48 AM
Registered User
Im running tr7 plugs i have a set of b8es plugs but i dont use them till track day. And im going to pull my timing down 2 more degrees to see how it does. Keeping it on 93 unless i get backed into a hp corner. I also droped 300lbs of curb weight from the day i was on the track
Hunting down that 11.99 pass on a stock converter lol
Old Apr 12, 2014 | 11:22 PM
BLKSSLTT's Avatar
formerly turbo4.8 (2014-06-25)
Why a tr7? Why not a br7ef?
Gadgetized
Aug 21, 2020 03:14 PM
Razor
Dec 1, 2015 10:46 AM
slowlsx
Aug 13, 2015 08:28 PM
slowlsx
Aug 10, 2015 05:33 PM
