Timing, nitrous, race gas
Should i pull more timing?
23 degrees on top with a 230 shot from 3,000 on a window switch full wieght 2500hd 6.0 12.38 @ 111mph (stock stall) pulled hard the whole track, no knock detected I run 93 pump gas always, if i add 110 or c-16 to my tank will it affect my factroy o2 sensors? Would it be worth the cost over the benifit? |
Run a stand alone fuel cell with c16. Yes you need to pull more timing.. Do alot of reading on yellowbullet.com in the nitrous section on reading plugs. What plugs are your running?
Really work on reading the plugs. You would be surprised how often nitrous builds will go faster on a little less timing.
Originally Posted by gamble686
(Post 5207992)
Trey |
(Post 5207992)
Im running tr7 plugs i have a set of b8es plugs but i dont use them till track day. And im going to pull my timing down 2 more degrees to see how it does. Keeping it on 93 unless i get backed into a hp corner. I also droped 300lbs of curb weight from the day i was on the track
Hunting down that 11.99 pass on a stock converter lol |
Why a tr7? Why not a br7ef?
