Timing for a kill tonight....
Old Feb 27, 2008 | 06:27 PM
  #21
WJ MARK's Avatar
This is why im a fan of wet kits. You won't have to worry much about starving for fuel.
Old Mar 3, 2008 | 12:49 PM
  #22
99Silverado5.3's Avatar
Might be a bad bottle or bad gas. Freezing the MAF is a myth.
I would try again on another bottle and tank of gas and see if that helps.
Old Mar 3, 2008 | 11:13 PM
  #23
LMSeven's Avatar
You didn't use Teflon tape for your fittings did you? Do you have a n20 filter? You should look into a bottle heater....
Edit: good kill.
Old Mar 4, 2008 | 11:50 AM
  #24
sickREDsierra's Avatar
no, no tape on anything. i use pipe sealant on pipe stlye npt fittings, and nothing on the flare fittings, as they are supposed to be.
i have no filter and no bottle heater, i am beginning to think my tune is still a bit off.
Old Mar 4, 2008 | 10:53 PM
  #25
Blue06's Avatar
Very simple. I've encountered this many times. Low bottle pressure. If it was cool out, and you don't have a heater...........it means you dont have enough pressure. Put a heater on that bitch!! Remeber, most systems are designed to work between 800-1050 psi.
Old Mar 5, 2008 | 06:44 AM
  #26
i didnt think low bottle pressure was that much of a factor with a dry kit?
Old Mar 6, 2008 | 08:30 PM
  #27
You're right it wouldn't be missing, just down on power. Wet kit it will do some some funky stuff.
Aug 21, 2015 11:33 PM
Hmguyton
Aug 9, 2015 05:38 PM
Wareagle23
Aug 8, 2015 10:06 AM
therock
Jul 25, 2015 09:23 AM
Moto733
Jul 12, 2015 10:25 PM
