Tach signal wire??
Old Jan 12, 2008 | 04:34 PM
Blue06's Avatar
Default Tach signal wire??
Hooking up HSW interface and would like to know what color , and pin# is the wire for the tach signal??
Old Jan 12, 2008 | 05:37 PM
laynlow77's Avatar
there is a tach signal wire behind the gauge cluster...it is pin a4...i believe its a green with white stripe.
Old Jan 12, 2008 | 07:28 PM
Blue06's Avatar
Thank you!! this helps a bunch!!
Old Jan 13, 2008 | 03:01 PM
brodystruck's Avatar
I grabbed one coming right out of the PCM harness. It's white. Forgot the pin number, I searched LS1Tech for it...
Old Jan 13, 2008 | 07:39 PM
Blue06's Avatar
Thanks guys!!
Old Jan 13, 2008 | 08:08 PM
laynlow77's Avatar
did that work for ya?
Old Jan 13, 2008 | 08:16 PM
Blue06's Avatar
I have'nt worked on the truck in a couple of days. Been busy with the Family.
Old Jan 13, 2008 | 10:34 PM
2002C5COUPE's Avatar
i could have swore the tach signal wire was white on the back of the cluster
Old Jan 13, 2008 | 10:42 PM
truckmann's Avatar
I believe you are correct....Cluster pin A5, white wire.
Also at the PCM Green plug pin 10
Can also go to any of the ignition coils or fuel injectors and use the wire that is NOT pink, black, or brown.
Old Jan 14, 2008 | 01:17 PM
Holty's Avatar
Notorious BIG
hey that is good to know, thanks
