Spraying through shifts?
Old Mar 2, 2007 | 01:38 PM
slowprocess's Avatar
IMO, a 4l60e is only going to take so much, regardless of spraying through the shifts or not. I just don't like the idea of shocking the tranny right before and after it shifts. Your stock tranny will be on borrowed time, just as it would be if you did a cam/heads/etc N/A setup. They would both make about the same power and you can't cut N/A power off right before a shift.
Old Mar 2, 2007 | 02:41 PM
UBLUZIN03's Avatar
I dont have nitrous yet...but hopefully soon... So i guess getting a window switch is a good idea...
Old Mar 2, 2007 | 03:21 PM
I blew a built tranny with a window switch installed. I'm spraying through the shifts now with a bigger shot and not using a window switch............you be the judge.
Old Mar 2, 2007 | 03:26 PM
RoosterMcCandles's Avatar
Almost every 4L60E is on borrowed time, expecially with nitrous. It will go on nitrous not spraying through the shifts, but chances are it will go faster if you spray through the shifts. I guess a window switch helps with risk management. It isn't go to save your tranny but it could prolong it for awhile...
Old Mar 2, 2007 | 05:51 PM
onebadrubi's Avatar
That is all in personal opinon. ANYone spraying a built 60e IMO is most likely spraying thro the shifts. I only bought a window switch to save the life of the tranny and not spray thro the shifts. But the most of hte time the parts that go arnt shift related nessiarily.
Old Mar 2, 2007 | 07:07 PM
I should have noted that 'every 4L60E' meant every stock one...I do agree, built ones usually won't have a problem spraying through the shift...
Old Mar 2, 2007 | 08:37 PM
05RST2NV's Avatar
Exactly what he said..! And if your going to spray through shifts on a 4l60 a servo and wake up kit is a must have...! You just hold the button and go.! And a servo and wake up kit will make your tranny last much longer..
Old Mar 3, 2007 | 08:16 AM
UBLUZIN03's Avatar
I def. buying a transgo hd-2 shift kit and vett servo befor i buy nitrous so hopfully that will help. I also only plan to use nitrous at the track......
Old Mar 4, 2007 | 07:11 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
Here is my window switch. Right before it shifts, I let go of the switch. It also helped with traction in that I didn't hit it until I knew the truck was hooked. I only ran a 100 dry shot, but like the idea of being able to control the hit.
Old Mar 6, 2007 | 04:57 PM
Damn, your window switch looks just like mine!
