sprayed half track 12.54
the last time a tried to spray was on the line.Broke the Axle,we put a stock one back in it because it was free.Then we took it back down to the track and it was real real windy and ran 12.54 108mph I think we can it an 11's if we could spray from the line
How big of a shot are you running? Looking at your sig, you shaved a little over a second and picked up 10mph only spraying half track??
I am also curious about the rest of your setup. Motor size, head/cam specs?
i am spraying a 150 shot right now,but the problem is it has a stock 5.3 bottom end in it for now.I am about to put a ls6 intake on it and run a little bigger injectors.The heads I am runnings are 4.8 heads with a little work done to them.And a lunati cam with 222-230 540
Vortec350ss
Jan 12, 2016 10:36 PM
