Speed Density, Dry Shot
Old Mar 29, 2006 | 06:07 AM
  #21
Sport Side's Avatar
Originally Posted by Flyer
o2 readings are a direct result of the 02's. The MAF won't have much to do with them.
The MAF will have everything to do with the O2 readings while using a dry shot.
If the MAF was injured/disabled or even frozen at the time, it will not sense the N2O passing by it's wires and therefore, the injectors will not inject the proper amount of additional fuel.
Old Mar 29, 2006 | 07:52 AM
  #22
Flyer's Avatar
You are correct ... my point was the o2 READINGS are solely from the o2's, it doesn't filter it's readings from any other sensor, it's a direct result of how much oxygen is in the exhaust. More oxygen, lower the reading in mv, lower the reading, the leaner its running.
Old Mar 29, 2006 | 10:50 AM
  #23
parish8's Avatar
single digit dreamer
this entire way of spraying seems like a bad idea to me. too many things to worry about.with a wet kit you put in a jet and are done.
i spray dry by it is completely different. the computer(megasquirt) is actualy comanding the nitrous to come on and is adding a preset amount of fuel for me once it comes on. i tried going dry thru the maf and it just didn't work well and this was just with a 75shot.
there are huge gains to be had with moderate shots on these trucks, especialy if you do silly things like spray it at lower rpms with a stock stall. i gained about 2.5sec's with just a 100shot on my truck when it was stock. 16.4 down to a 13.9
Old Mar 31, 2006 | 07:50 AM
  #24
Sport Side's Avatar
Default Video @ Bottom
Well, it hit way too hard. Just roasted the tires and then I ran into some other problems.
The nitrous is just blowing thru the target shift points. I had it set for 5200 in first gear and it hit the fuel shut off of 6100. I forgot to raise this... New tune.
Then, it shifted into 4th gear.
I had my all-motor shift points set... Tought night.
100 shot out of the hole
Old Apr 1, 2006 | 12:46 AM
  #25
parish, what shot did you use? i am s going to be running a 150 wet and shortly after that a 3600ish rpm stall to better accomidate my cam but what kind of gains would i be looking at. i never expected upwards of 2 seconds on such a moderate shot
Old Apr 1, 2006 | 09:08 AM
  #26
parish8's Avatar
it was just a 100shot. you have to remember i was running a stock "stall" , and a lowly4.8. put those 2 things together and you have a prety slow truck off the line. i was spraying the truck right out of the hole with a 100shot and geting big gains in my 60'time. i am 4wd too so traction wasn't an problem. spraying off the line with a stock converter is prety risky, dont do it if a broken piston or a small backfire is going to ruin your day.
the more mods you have and the faster your truck is NA the less the nitrous seems to help but it is still a killer bang for the buck mod.
Old Apr 16, 2006 | 07:04 AM
  #27
Sport Side's Avatar
Decided to go back with the MAF.
twake_410
Apr 14, 2016 09:58 PM
bearden86
26
Nov 15, 2015 03:58 PM
BlownHD
Oct 3, 2015 12:24 PM
Lthompson
Oct 2, 2015 12:45 AM
Slammed silverado
Sep 28, 2015 06:14 PM
