spark plug question
Old 03-20-2014, 08:52 AM
calboi's Avatar
Default spark plug question
im new to the whole nitrous thing and heard its a safe insurance basically to run colder plugs my question is since i will only be running the bottle at the track and 1-2 on street for fun red to red will the 2 step colder plugs affect the n/a side of the trucks performance.... also i got ngk 3346-br7ef plugs are these correct????
Old 03-20-2014, 01:44 PM
chriscon7's Avatar
I believe most run NGK TR6 for nitrous. They are only one step cooler than stockers
Hell I am running them without nitrous due to my tune, truck doesnt run any different.
Old 03-20-2014, 02:16 PM
calboi's Avatar
well that sucks i already bought these
Old 03-20-2014, 03:11 PM
TXsilverado's Avatar
the new way says not to use a tr6 and to get a non projected tip plug. how much compression do you run and how big of a shot are you planning?
Old 03-20-2014, 03:14 PM
05GMC4.8's Avatar
how much are you planning to spray? if u plan to hit it with 150 or more use what u have. I was running the non projected tip version of the tr6 plugs, but switched to the tr6 since I cant find the others as easily locally.
Old 03-20-2014, 03:50 PM
calboi's Avatar
its pretty much a stock motor with the typical bolt ons and a cam and i plan on spraying a 150 shot at most
Old 04-02-2014, 10:06 AM
Fast6.3's Avatar
The recommended plugs for a 150 shot are the bref7 some say they run fine others have commented bad idle i run bref6 on my 2011 camarao and it runs great but Ive only hit it with a 100 shot i have a set of the bref7 for when i hit it eith 150
Old 04-02-2014, 02:20 PM
Former Vendor
NitrousExpress's Avatar
I would recommend you use the BR7EFs if you are going to be spraying 150hp. Also you will want to gap them at about .032.
These are what I run in my personal truck and I do not notice any power loss while using these plugs. I have notice that they can fol out a little easier and faster than a higher heat range but luckily they are only $2 a piece.
Trey
Old 04-02-2014, 11:04 PM
Fast6.3's Avatar
you can also tune to run the bref7 and it will run fine
Old 04-05-2014, 08:08 AM
calboi's Avatar
cool aight thx guys glad i already got the right ones then
Quick Reply: spark plug question
