Safe spray?
Old Dec 19, 2005 | 09:33 PM
virgils4.85spd's Avatar
Default Safe spray?
I have a 4.8 5spd with 112,000 mi. Im gettin the 224 112 tr cam. Im thinkin of a little nitrous too. I want the setup where it only sprays at full throttle by placing a switch behind the throttle body. How should i do my setup? Whats the safest way? I was thinkin no more than a 100 shot through the intake tube on that motor, but i don't know? What do yall think?
Thanks
Virgil
Old Dec 19, 2005 | 09:39 PM
goshawk23's Avatar
Truck addict
me personally i would go with a wet shot. you will use a micro switch that the throttle blade will make contact with and allow the circuit to close for the noids to activate. with a manual you will need a window switch so you don't spray nitrous while your are shifting. there are several choices in that field. harlan, msd, i think nx has a switch along with others.
do you have tuning? if so, i would back the timing down 2 to 4 degrees and change over to ngk tr6 plugs.
Old Dec 19, 2005 | 10:00 PM
Sport Side's Avatar
I personally think a small dry shot is the safest when it comes to 'user' error.
Dry shots...
1. are less expensive
2. require 1 solenoid
3. let the MAF do the 'thinking' by...
3a. correcting the a/f ratio
3b. decrease timing advance
4. can run the bottle to empty without dumping tons of fuel because...
4a. the MAF is monitoring
5. do not require a purge system
The last detail that I can think of, off the top of my head is this.
A small dry shot will not have any problems with backfires thru the intake manifold when spraying at low RPM. You could blow the motor but, we are discussing small shots so you should be safe.
Old Dec 20, 2005 | 12:02 AM
onebadrubi's Avatar
with what you are saying sport side would a 100 shot be to big?
Old Dec 20, 2005 | 07:08 AM
Sport Side's Avatar
Yes... but,
I think it would depend on the amount of mods you have done. Take for example Virgil, he's dropping a 224* cam in his motor. That plus a 100 shot will probably exceed the stock fueling capabilities.
Also, I'd want to take a look at the timing cells. When you spray thru the MAF it enters a higher load...
Stock, these values are lower but low enough for a 100rwhp shot? Some think so, others do not.
Old Dec 20, 2005 | 07:23 AM
onebadrubi's Avatar
I am new to the spraying world. I do not completely understand what you are saying. What would you recommend for my truck...completely stock motor besides headers, wait4me tune, and intake.
Old Dec 20, 2005 | 08:49 AM
white1's Avatar
Dry shots...
What do you consider a "small" shot?
Old Dec 20, 2005 | 01:44 PM
Scrapin'4.8's Avatar
I've got an NX wet kit on mine w/no window switch or fuel safety switch and a W4Me tune and it's a bitch with just the 75 shot. But virgil, i don't know if you've still got an open rear or not b/c if you do, everything your doing to your truck is gonna be a waste b/c u won't be able to put any of it to the ground and keep from spinning. I've been there, the nitrous was useless til around 70mph and all i had was the tune, intake, and exhaust, check into an eaton before u do anything else.
Old Dec 20, 2005 | 03:52 PM
Rhino79's Avatar
9 Second Club
125 is perfectly fine on a stock motor with the stock intake. The Wood Hauler has sprayed at least 12-15 bottles through his stock 4.8l and has had NO PROBLEMS.
Dry shots...
How is relying on the mass air flow safer than manually adding the fuel with a wet kit? Wet kits are safer and have more ability to make higher power levels. Just go 2 steps colder with your plugs and you will be fine.
You will see Thursday night when The Wood Hauler runs that Lightning, that a 125 is completley safe!
Old Dec 20, 2005 | 04:40 PM
white1's Avatar
I was just wondering what a "safe" dry shot would be. If I go wet I plan to spray 100-125.
