Safe 4.8 Spray?
Old Sep 8, 2006 | 04:36 PM
superfox's Avatar
Default Safe 4.8 Spray?
How much the safe Wet Spray on 4.8 Some one tell me the 4.8 pistons soo bad with the nitrous , i new on the Nitrous i have HSW kit ?
Old Sep 8, 2006 | 05:33 PM
goshawk23's Avatar
Truck addict
with a little timing pulled you should be able to spray 100 shot all day and up to a 150 if you have a fuel pump. others do it on the stock pump but i wouldn't. but you should be fine spraying a 100 shot with no other upgrades.
Old Sep 8, 2006 | 07:04 PM
GoldenVelvet's Avatar
Exactly what he said.
Old Sep 8, 2006 | 09:16 PM
superfox's Avatar
sound like Good , i will install it today
Old Sep 8, 2006 | 10:51 PM
BlaCK-on-BlacK's Avatar
Default hmmm
by the way wich fuel pump's is the best 4 it ?
and thanks
Old Sep 9, 2006 | 08:02 AM
slowprocess's Avatar
and thanks
Several have gone with holley 255 with the same part number as a mustang drop in.......at least Goshawk23 did. That's the same pump I'm going with for the 200 shot.
Old Sep 9, 2006 | 11:24 AM
goshawk23's Avatar
Truck addict
it's not a direct drop in though. you will have to modify the fit. ranwalk and another guy did a write up on the subject in the gm performance section
Old Sep 9, 2006 | 12:30 PM
litreddevil's Avatar
Banned
the pump is not to bad to do i did goshawk one and i think i will be doing slows one next week end when we put his trany in.then i am going to go on the hwy and smoke his ***.
by the way you can spray up to 150 with stock pump slow is doing just that with out popping a motor **** john put a motor n today and tomorrow takes it back out cause he gose run it lean don't listen to him
RustyD
May 23, 2016 07:04 PM
AdaMax
May 16, 2016 11:35 PM
twake_410
Apr 14, 2016 09:58 PM
turbo6c3
Oct 5, 2015 06:11 PM
carid
Oct 1, 2015 09:22 AM
