Ported my intake with nitrous
Old Oct 11, 2008 | 04:52 PM
tarinitup's Avatar
9 Second Truck Club
Which plate would be better? The 90mm that goes behind the throttle body or the one that sits on top of the intake. If anyone can post a link to the correct plate I would appreciate it. There are tons of plates out there and I want the right one.
Old Oct 13, 2008 | 06:41 PM
tarinitup's Avatar
9 Second Truck Club
Vic jr, elbow, and Nick Williams Throttle body ordered. Just need a nitrous plate.
Old Oct 13, 2008 | 07:25 PM
2004SSS's Avatar
could do this
its hard to see but it has a built in spray bar so you dont need the spacer. it has small holes drilled in the two bars that are aimed at each cylinder. almost the same as direct port
Old Oct 13, 2008 | 07:41 PM
BlackGMC's Avatar
Resident Retard
Originally Posted by 2004SSS
could do this
Oh my!!!! That is freaking awesome looking!!!
Old Oct 13, 2008 | 07:43 PM
LMSeven's Avatar
That is bad ***.
Since your spraying 250hp worth of N20, I'd go with a D.P. progressively controlled. You could still spray 50 out of the hole and ramp it up to 250. Not to mention you can tune per cylinder.
Old Oct 13, 2008 | 07:44 PM
tarinitup's Avatar
9 Second Truck Club
That looks really nice. Who does it and how much does it run?
trever1t's Avatar
2nd fastest 5.3 ECSB
Sorry to hear of the mishap, how was it doing before it popped? You were on the track I assume?
Old Oct 13, 2008 | 07:51 PM
regency's Avatar
Originally Posted by tarinitup
Is there a plate for that setup? I have only seen them for 90mm or 75mm.
here ya go!!!
http://nitrousoutlet.com/catalog/pro...roduct_id=3107
Old Oct 13, 2008 | 07:59 PM
BlackGMC's Avatar
Resident Retard
I bet trick could do something like that, don't they make a similar rail for the lightning guys???
Old Oct 13, 2008 | 08:25 PM
tarinitup's Avatar
9 Second Truck Club
Originally Posted by regency
I did the vic jr with 90mm instead but that's a good plate for the 85mm guys.
