NX proton kit for my tahoe!
Old Jul 25, 2014 | 12:46 AM
josueh95's Avatar
ohhh really?? that helps out alot then...soo each solenoid has a black and a blue wire comming out so the two blacks tie together and ground to a bolt and the two blue go to the green cable that hooks to the relay?
Old Jul 25, 2014 | 08:15 AM
redram2007's Avatar
I bought my proton kit new and the solenoid wires were already tied together. Inside the red heat shrink(positive) was one blue and one black, and the black heat shrink(ground) was one blue and one black.
Old Jul 25, 2014 | 09:07 AM
Nitrous Express's Avatar
Former Vendor
NO... that will not work! one black wire and one blue wire go to ground and the other black and blue wire go to positive. that is why they are heat shinked in red and black heat shrink.
Follow the wiring diagram in the proton instructions, if you are not using a NX relay harness the wire colors correlate to these pins on the relay.
Red-86
Blk-30
Wht-85
Grn-87
Hopefully this helps
Correct
Old Jul 25, 2014 | 11:57 AM
josueh95's Avatar
Red-86
Blk-30
Wht-85
Grn-87
Correct
PERFECT! thats the last piece of info i needed to complete my installation..thanks alot
Zizzle
Oct 19, 2017 08:44 PM
thunder550
Oct 8, 2015 04:53 PM
brandon6.0
Aug 7, 2015 11:22 PM
Breitling
Jul 6, 2015 06:39 PM
Breitling
Jul 6, 2015 04:50 PM
