Nozzle Placement
Old Dec 12, 2005 | 01:05 PM
brodystruck's Avatar
Default Nozzle Placement
This is a wet kit. And I just want to make 100% sure that where I plan on putting this thing is ok.
Will putting it right underneath the coolant hose be an ok spot for it?
ps: please excuse the drops of oil
Old Dec 12, 2005 | 02:07 PM
nosfedgta's Avatar
9 Second Club
ussuakt you syhould put it about 4-6in in front of the throttle body. If you look at your pic above, I would put it in the right side of the elbow about 6 in back or so. That is where I put them when I do an install....
Old Dec 12, 2005 | 06:25 PM
I dont have enough line to put it on the radiator side of the pipe. It's gotta go on the firewall side, where should it be???
Thanks
Old Dec 12, 2005 | 06:38 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Put it in the 90* elbow where it is spraying at the tb here is what mine looks like do something like this
Old Dec 12, 2005 | 06:39 PM
1slow01Z71's Avatar
Some say it is too close to the tb but I have sprayed close to 40 bottles through it with NO problems so there isnt a problem with the location IMO.
Old Dec 12, 2005 | 09:12 PM
fullthrottledan's Avatar
mine is right infront of the tb as well. ive tried back where you are talking about and then i moved it. it "hits" alot harder right infront of the tb
Old Dec 12, 2005 | 11:46 PM
It's mounted, I'll take a pic sometime of where it's at...
I sprayed for the first time tonight (just a relitevely low pressure) 50 shot.
I love this ****...
GXPJAY
Feb 13, 2022 08:15 AM
Mr. Chainsaw
Oct 18, 2015 08:00 PM
bgray
Sep 16, 2015 07:33 PM
custm2500
Aug 22, 2015 11:46 PM
