Nitrous Setup Pictures...LET'S SEE 'EM!!!!
Old May 31, 2011 | 02:27 PM
  #31
00buckshot's Avatar
So you removed the vic? why do you think the power was different?
Old May 31, 2011 | 02:29 PM
  #32
Phantom's Avatar
11 Second Club
It's magic
Old Jun 1, 2011 | 06:47 PM
  #33
SRTKLLR's Avatar
Here are some pics of mine. Can't see much though unless I pull off the engine cover.
You can see the install pics in this thread.
https://www.performancetrucks.net/fo...d.php?t=477128
Old Jun 8, 2011 | 10:49 PM
  #34
bmd_CL's Avatar
what else do you have in your truck srtkllr?
Old Jun 9, 2011 | 12:30 PM
  #35
SRTKLLR's Avatar
Low cr 408 with heads/cam. Everything else is stock.
Old Jul 15, 2011 | 08:24 PM
  #36
ThunderTruck's Avatar
Well I'll show my ride, a '77 F150 with a 472 (60 over 460) and twin 50lb nitrous bottles feeding a plate jetted for 180hp with water/methanol injection:
Old Jul 15, 2011 | 08:54 PM
  #37
6789olds's Avatar
wow thats a lot of nitrous
Old Jul 15, 2011 | 11:18 PM
  #38
Phantom's Avatar
11 Second Club
How the hell do you maintain bottle pressure?
Old Jul 16, 2011 | 12:15 AM
  #39
bmd_CL's Avatar
On the regular cabs, where is the best place to run the nitrous feed line into the cab? Or do you have to go ahead and drill a hole? Where is the best place to mount the solenoids or does it matter? And for the drive by wire throttle bodies what would i use for a wide open throttle switch?
Old Jul 16, 2011 | 01:23 AM
  #40
6789olds's Avatar
Drive by wire u can use the tps switch the will Sence the voltage of wot.
