nitrous question
Old Mar 8, 2011 | 09:48 PM
SRTKLLR's Avatar
Originally Posted by custm2500
You can never learn too much and we all want everyone to have fun but nobody has fun blowing up there motor the first time they spray.
I figured with a controller you can use the TPS to get a signal but you can't use it for a WOT switch can you?
They sell electronic TPS switches for those with a drive by wire TB who don't want to use the old school "micro switch". Also, most modern Window switches and Progressives also come with a built-in TPS WOT switch.
Old Mar 9, 2011 | 05:54 AM
too slow's Avatar
My local chevy performance shop said that the wot wire on the tb will read 0 then wot will read 5 like y'all have already stated...I think ill try that method starting with maybe the 25 shot and get me some of those tr6 plugs...thanks for helping and good luck with all your future builds
Old Mar 9, 2011 | 08:29 AM
custm2500's Avatar
Ph.D. in HUBRIS
Don't waist your time with 25.
Old Mar 9, 2011 | 12:28 PM
06Sierra2's Avatar
get the tr6s pull 2* and spray a 50-75 shot and go from there. thats what i plan on doing once i get back from deployment. 25 would be a waste of time.
Old Mar 9, 2011 | 03:19 PM
too slow's Avatar
Do you have to pull 2* or can you leave that alone
Old Mar 9, 2011 | 04:03 PM
blackcash's Avatar
Don't pull timing with a little shot like that. Unless your tune is already on the ragged edge
Old Mar 9, 2011 | 05:01 PM
walledition's Avatar
not everyone has this luck but i sprayed 125 without taking any time away, but i took baby steps to get there
but i was on stock tune back then
Old Mar 9, 2011 | 05:15 PM
too slow's Avatar
Yea I'm on a stock tune too...do you have to mess with your fuel or is that a no also?
Old Mar 9, 2011 | 05:21 PM
custm2500's Avatar
Ph.D. in HUBRIS
The controller will add the fuel on a dry system.
50-100 no need to pull timing but at a 75-100 a good bit of insurance is high octane fuel. My self I have a fairly aggresive tune ran a 100 shot and 110 octane fuel wile spraying. Never had any issues and ran about 10-12 passes.
Old Mar 9, 2011 | 05:24 PM
blackcash's Avatar
The PCM will also add fuel for a dry shot. That's the point of mounting the nozzle upstream of the MAF.
