Nitrous Piston Rings
Old Mar 17, 2015 | 12:24 PM
L$X$10's Avatar
Default Nitrous Piston Rings
Looking to pull the trigger on a set of rings today. Setup: cleaned up aluminum 347 with stock rods, pistons, crank + aftermarket cam and supporting valvetrain. Planning to start on a wet 150 and possibly work my way up to a 250 shot. What rings would be ideal for my weekend street/strip setup? I know there are a lot of people running OEM, and I have looked into the Hellfires, but they seem to be overkill. What's recommended that fall's in between? These Sealed Power E938K's seem to be fairly reasonable:
Amazon.com: Sealed Power E938K Premium Piston Ring: Automotive Amazon.com: Sealed Power E938K Premium Piston Ring: Automotive
Old Mar 17, 2015 | 12:31 PM
L$X$10's Avatar
"If you're going to spray alot, the kind piston is going to matter a little more compared to what the ring is made of.
A piston with the ring down further in the bore with more meat on the ringlands to me is more of an issue. Plus having a good compression height
A good ring on a not-so-good of a piston choice is a worse situation than a mediocre ring on a good piston."
-87silverbullet
Do most concur with this statement?
Old Mar 17, 2015 | 06:01 PM
L$X$10's Avatar
Pulled the trigger on the Perfect Circle 41850CP's
Old Mar 17, 2015 | 07:39 PM
dirt track racer 81's Avatar
Agree with that.. I'm running Wiseco pistons with a thick ringlands along with the rings that come with them, steel top, Napier second ring.
Old Mar 17, 2015 | 07:47 PM
Reason for running thicker rings is to make the pistons more tolerable of a bad tune up. If you have a thin ring land and you run your nitrous tune too rich, you'll get unburnt fuel and nitrous in the top ring and when it does ignite it will lift the ringland and lock up the rings.
It can still happen with forged pistons as well but they are just more tolerable and if you run stock pistons your tune needs to be dead on.. I'd rather have a lean tune up than a rich tune up..
Old Mar 17, 2015 | 09:03 PM
GREENSIERRA's Avatar
dirt track what do you have your rings gapped for your nitrous on the weiscos?
Old Mar 17, 2015 | 09:43 PM
.029-.032 something like that, it was two years ago when I built it.
OHsixLS3
Nov 22, 2015 07:45 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
turbo6c3
Oct 5, 2015 06:11 PM
sTNT971
Sep 26, 2015 04:22 PM
