Nitrous expressProton plus and purge kit
Old Oct 5, 2013 | 12:15 AM
Jake75's Avatar
Default Nitrous expressProton plus and purge kit
Finally getting around to installing my proton plus and purge kit wanted to make sure I have this set up right before I put it all in the truck. Connected the purge solenoid to inlet side of n2 and connect the main line from the bottle on the black nipple.Name:  null_zpsea0dac43.jpg
also if I want to make the purge tubing longer can I replace the tubing supplied and maybe t it off to have two purge lines (mainly for show)
Old Oct 5, 2013 | 02:39 PM
musclecity85's Avatar
yes its installed right..and yes you can replace the tubing. when i run my purge line i have always used brake line from the part store, just get the size and length you want
Old Oct 5, 2013 | 02:49 PM
Jake75's Avatar
ok thank you! will 1/4" be ok for purge?
Old Oct 5, 2013 | 08:25 PM
yes it will work just fine
Old Oct 6, 2013 | 05:53 AM
Jake75's Avatar
should i use the supplied WOT switch or get a push button?
Old Oct 6, 2013 | 03:04 PM
Blwn99x's Avatar
Wot switch, push buttons can get activated at the wrong time...make stuff go boom!
Old Oct 6, 2013 | 04:12 PM
Jake75's Avatar
How does the wot switch work usually when I'm racing my foot stays on the pedal bottomed out
Old Oct 6, 2013 | 07:31 PM
Steve-O-08's Avatar
The WOT switch can either be a mechanical switch activated at full throttle or electronically activated by TPS voltage at full throttle.
Old Oct 7, 2013 | 11:41 AM
NitrousExpress's Avatar
Former Vendor
Yes the purge is installed right.
We use 3/16 tubing for the purge line but yes the 1/4 will work just fine.
I would also recommend a WOT switch because as Blwn99x said if the button is pressed at the wrong time such as before you are full throttle it can cause a back fire. The same thing could happen if you let off the throttle and not the button.
There are a couple of different ways to do the WOT like Steve-O-08 said. If you use a mechanical switch you either mount it out by the throttle linkage (If you are drive by cable) or you can mount it to the gas pedal in the cab so that when you press the pedal all the way down it hits the mounting bracket for the pedal.
The other way is to use a tps activated switch which does everything electronically. This is the best way in my opinion because you never have to worry about the switch getting hit and moved and not activating when you need it.
Here are a couple of links to your options.
TPS Switch
Mechanical Switch
Trey
Old Oct 8, 2013 | 12:18 AM
Jake75's Avatar
Ok we'll I ordered the tps switch. The switch it shows on the diagram is that the nitrous arming switch or does it need it own? Also is the tps switch all I will need? No need for rpm window switch?
