nitrous cutting out!
Old Jan 17, 2006 | 01:35 PM
Default nitrous cutting out!
Hey guys my nitrous has been fine for the past week but all of a sudden when im going it just shorts out and then kicks back on repeatedly- my bro says one connection could be bad and it could arc but what do you guys think is wrong?
Old Jan 17, 2006 | 06:05 PM
goshawk23's Avatar
Truck addict
i suggest checking all of your wiring!!!!. i have had good wiring go bad just because a connector came loose. start there and also check your micro switch to ensure it is making good contact with your throttle blade if you use it there.
Old Jan 17, 2006 | 07:53 PM
yup i think i found it but i need to get another bottle first!!!!- i found a loose crimp in the wiring from the switch to the WOT switch, along w/ an exposed connection which i covered w/ electrical tape as i did w/ all the connections now, also found a small leak between the purge adaptor and the nitrous solenoid which i torqued down and covered w/ thread locker/sealant-
Old Jan 17, 2006 | 09:13 PM
AintNoHo's Avatar
I had an intermittant nitrous problem that drove me nuts for about 3 weeks. It was caused by the thin wires that go to the solenoids. When crimped it would cut through the wire leaving it only connected by a few strands and every time it moved, I would gain or lose continuity. That's why they say don't use vise-grips to crimp. Now, I use solder to insure a good connection.
Old Jan 18, 2006 | 09:35 PM
do you guys think it could be a leak in the nitrous line??? Because i have a leak that wont stop with no matter how much tightening or thread sealant IT JUST WONT STOP and the nitrous is still cutting in and out..... please help- or maybe could it be the WOT switch boucing around but i checked it and i cant move it hardly at all- this is getting really old..... any ideas?
smok'nZ
Oct 6, 2015 01:14 PM
GMCtrk
Oct 5, 2015 11:18 AM
JordanH
Oct 3, 2015 03:59 PM
chvy=power
Sep 28, 2015 10:32 AM
